I have the following code made by a friend, who sends text messages in the morning and in the evening with the data from the humidity, temperature and weight sensor. And I receive empty text messages without any information. Can you help me get over it, please.
#include <DS3231.h>
DS3231 rtc(SDA, SCL);
Time t;
#include <dht.h>
#include "HX711.h"
#include <SoftwareSerial.h>
int messagecount = 0;
const int LOADCELL_DOUT_PIN = 3;
const int LOADCELL_SCK_PIN = 2;
#define dataPin 7
HX711 scale; // working
dht DHT;
SoftwareSerial sim808(4,5); // RX, TX
String dataforgsm;
char phone_no[] = "+40760000000"; // replace with your phone no.
String data[5];
#define DEBUG true
String state,timegps,latitude,longitude;
int k=0;
char msg;
char call;
sim808.begin(38400);
Serial.println ( "check");
delay(50);
rtc.begin();
// Here to set the time , day and date.
rtc.setDOW(WEDNESDAY); // Set Day-of-Week to SUNDAY //
rtc.setTime(21, 05, 0); // Set the time to 12:00:00 (24hr format)
rtc.setDate(15, 4, 2020); // Set the date to DD/MM/YYYY
Serial.println ( "check1");
// Setup code for GSM Start
sim808.print("AT+CSMP=17,167,0,0\r"); // set this parameter if empty SMS received
delay(100);
sim808.print("AT+CMGF=1\r");
delay(400);
Serial.println ( "check2");
sendData("AT+CGNSPWR=1",1000,DEBUG);
delay(50);
sendData("AT+CGNSSEQ=RMC",1000,DEBUG);
delay(150);
// Setup code for GSM end
scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
scale.read(); // print a raw reading from the ADC
scale.read_average(20); // print the average of 20 readings from the ADC
scale.get_value(5); // print the average of 5 readings from the ADC minus the tare weight (not set yet)
scale.get_units(5), 1; // print the average of 5 readings from the ADC minus tare weight (not set) divided
scale.set_scale(44.5f); // this value is obtained by calibrating the scale with known weights; see the README for details
scale.tare(); // reset the scale to 0
Serial.println ( "check3");
int kg = 0;
int smscounter = 0;
void loop(){
t = rtc.getTime();
Serial.print( t.hour);
Serial.print( ":");
Serial.print( t.min);
Serial.print( ":");
Serial.println( t.sec);
//int modiifytime = timing;
sendTabData("AT+CGNSINF",1000,DEBUG);
delay(300);
if ( t.hour == 7 && t.min == 00){ // dow = day, Mon = 1, Tues= 2, ... Sunday = 7, t.hour = hour 24 hours, t.min = minute, t.sec = seconds At this time it will send message.
if (k<=10){
SendMessage();
k++;}
Serial.println ( " sms sent");
if (t.hour == 20 && t.min == 00 ){ // 20: 00 condtion to send sms,
if (k<=10){
SendMessage();
k++;
delay(200);
sim808.println((char)26); // End AT command with a ^Z, ASCII code 26
delay(200);
sim808.println();
delay(20000);
sim808.flush();
Serial.println ( "loop finished");
if ( messagecount == 1)
{ delay ( 30000);
messagecount = 0; }
String sendData (String command , const int timeout ,boolean debug){
String response = "";
sim808.println(command);
long int time = millis();
int i = 0;
while ( (time+timeout ) > millis()){
while (sim808.available()){
char c = sim808.read();
response +=c;
if (debug) {
Serial.print(response);
return response;
void SendMessage()
{ messagecount = 1;
int readData = DHT.read22(dataPin);
float temp = DHT.temperature;
float humidity = DHT.humidity;
Serial.print("Temperature = ");
Serial.println(temp);
Serial.print("Humidity=");
Serial.println(humidity);
// Serial.println(scale.get_units(10), 1);
float khali=scale.get_units(10);
//Serial.println(khali);
kg = 0;
if ((khali>=1000.0) || (khali<=-1000.0)) // Done
{ khali=khali/1000;
kg = 1;
if ( khali<0)
{ khali = -1 * ( khali); }
Serial.println ("Check point 1" );
//Serial.println (khali);
String weight= String (khali);
if (kg == 1)
{ weight= weight + String("kg");}
{ weight= weight + String("g");}
String humid = String (humidity); // convernting from float to String
String tempera = String ( temp) ; // convernting from float to String
String data = String("T") + String("_") + tempera + String("C_") + String("H") + String("_") + humid + String("%_") + String("W") + weight ;
Serial.println(data);
dataforgsm = data;
scale.power_down(); // put the ADC in sleep mode
delay(5000);
scale.power_up();
Serial.print("sending message");
sim808.println("AT+CMGF=1"); //Sets the GSM Module in Text Mode
delay(1000); // Delay of 1000 milli seconds or 1 second
sim808.println("AT+CMGS=\"+40760000000\"\r"); // Replace x with mobile number
sim808.println(dataforgsm);// The SMS text you want to send
delay(100);
//sim808.println("Lattitude is ");
//sim808.println(latitude );
// delay(100);
// sim808.println("Longitude is ");
// sim808.println(longitude );
// delay(100);
sim808.println((char)26);// ASCII code of CTRL+Z
void sendTabData(String command , const int timeout , boolean debug){
int i = 0;
while((time+timeout) > millis()){
while(sim808.available()){
if (c != ',') {
data[i] +=c;
delay(100);
i++;
if (i == 5) {
delay(100);
goto exitL;
}exitL:
if (debug) {
state = data[1];
timegps = data[2];
latitude = data[3];
longitude =data[4];
