I have a problem with tweaking the arduino code to work with my motor
First of all I'm a complete noob in this kinda thing. I'm currently working on our university project that I just happen to pick one of those project in github to be my project which is :
This is my motor that I used to work with this project : TowerPro MG995 Servo Specifications and Reviews
The question is how do I tweak the arduino code to work with my motor
// Course: ENSC 100W
// Group: Kappa
// Authors: Mateen Ulhaq, 301250828, mulhaq@sfu.ca
// Description: Receives input pitch (Hz) over Bluetooth.
// Runs transfer function converting Hz -> degrees and feeds into PID controller.
// Outputs to motor.
// License: GPLv3
// #define USB_DEBUG // USING SAME BAUD RATE AS BT!!
// #define TEST
#define ENABLE_BT
// #define ENABLE_PID
#define ENABLE_SERVO
// #define SERVO_WRITEUS
#include "Arduino.h"
#include "Notes.h"
// #ifdef ENABLE_SERVO
#include <Servo.h>
#include "Motor.h"
// #endif
#ifdef ENABLE_PID
#include <PID_v1.h>
#endif
#ifdef ENABLE_BT
#include <MeetAndroid.h>
#include "Comm.h"
#endif
#ifdef ENABLE_BT
MeetAndroid meetAndroid;
#endif
// TORQUE = 38 oz-in torque @ 6 V
const int RADIUS = 30;
const int AXLE_RADIUS = 10;
const int GEAR_RATIO = 1;
// PWR / w ~= 255 / (360 * rps)
const double PWR_OVER_W = 255.0 / (360.0 * 0.25);
// Motor
const int PIN_SERVO = 9;
#ifdef SERVO_WRITEUS
const int SERVO_RADIUS = 200;
const int SERVO_MIDPOINT = 1500;
const int SERVO_MIN = SERVO_MIDPOINT - SERVO_RADIUS; // 1300;
const int SERVO_MAX = SERVO_MIDPOINT + SERVO_RADIUS; // 1700;
#else
// Note that actual output commands are modulated
// so that it's between [t-0.2ms, t+0.2ms] pulses + 20ms pulse
// (When using PWM, not PPM)
// This means that if write is using a 1/t relationship,
// radius is not completely symmetrical
// i.e., midpoint+10 may turn at a different speed than midpoint-10
const int SERVO_RADIUS = 18;
const int SERVO_MIDPOINT = 94;
const int SERVO_MIN = SERVO_MIDPOINT - SERVO_RADIUS; // 76;
const int SERVO_MAX = SERVO_MIDPOINT + SERVO_RADIUS; // 112;
#endif
bool stopped = false;
int power = 0;
int frequency = 0;
int distance = 0;
#ifdef ENABLE_PID
// PID variables
double pid_in = 0.0;
double pid_out = 0.0;
double pid_setpoint = 0.0;
PID pid(&pid_in, &pid_out, &pid_setpoint, 0.3, 0.0, 0.3, DIRECT);
#endif
#ifdef ENABLE_BT
// Turn on Bluetooth communication at 9600 baud rate
meetAndroid.registerFunction(receivePitch, 'C');
meetAndroid.registerFunction(receiveCommand, 'X');
meetAndroid.registerFunction(receiveCommand, 'T');
meetAndroid.registerFunction(receiveCommand, 'S');
meetAndroid.registerFunction(receiveCommand, 'F');
meetAndroid.registerFunction(receiveCommand, 'N');
meetAndroid.registerFunction(receiveCommand, 'P');
#endif
#ifdef USB_DEBUG
#endif
#ifdef ENABLE_PID
// Set up PID controller
pid.SetOutputLimits(-255.0, 255.0);
pid.SetSampleTime(200);
pid.SetMode(AUTOMATIC);
#endif
// Turn on servo motor
#ifdef ENABLE_SERVO
myservo.attach(PIN_SERVO);
#endif
stopped = false;
#ifdef TEST
// Generate fake values for frequency
static int lastTime = millis();
if((lastTime + 200) <= millis())
frequency += (goalFrequency - frequency) / 4;
#else
#ifdef ENABLE_BT
// Receive pitch from android device
meetAndroid.receive();
#endif
#endif
#ifdef ENABLE_SERVO
// Transform input frequency into PID controllable input
// (Transfer function)
distance = pitchToDistance(goalFrequency, frequency);
#endif
#ifdef ENABLE_PID
// pid_error = pid_setpoint - pid_in
pid_setpoint = distanceToDegrees(distance);
pid_in = 0;
// power ~= velocity
// degrees ~= distance
// Note that power control is virtually instantaneous.
// So, integral term not needed...? PD control?
// out = velocity
// in/setp = distance
#endif
if(!stopped)
#ifdef ENABLE_PID
// Compute dTheta/dt
if(frequency > 0)
pid.Compute();
// Convert pid_out to power
power = angularVelocityToPower(pid_out);
power = 0;
#else
if(frequency <= 0)
power = 0;
else if((frequency >= (goalFrequency - 1)) && (frequency <= (goalFrequency + 1)))
power = 0;
stopped = true;
else if(abs(frequency - goalFrequency) > 5)
// power = constrain((goalFrequency - frequency) * 10, -255, 255);
if(frequency > goalFrequency)
power = 50;
power = -50;
power = 30;
power = -30;
#endif
#ifdef ENABLE_SERVO
rotateMotor(power);
#endif
#ifdef ENABLE_BT
static int lastSent = millis();
if((lastSent + 100) <= millis())
char TempString[63] = {0}; // Hold The Convert Data
#ifdef ENABLE_PID
sprintf(TempString, "Goal: %d, Curr: %d, Pow: %d, PIDout: %f", goalFrequency, frequency, power, pid_out);
#else
sprintf(TempString, "Goal: %d, Curr: %d, Pow: %d", goalFrequency, frequency, power);
#endif
meetAndroid.send(TempString);
#endif
#ifdef ENABLE_SERVO
rotateMotor(0);
// myservo.detach(); // Coast motors?
#endif
Start with basics. An MG995 is usually a servo with maximum travel of about 180 degrees. Is yours a continuous (360) servo that acts like a geared motor?
If it is then how are you powering it. Note: connecting it to the Arduino 5V pin is definitely the wrong answer for a powerful servo/motor.
Next when try it with that code what exactly does it do? What did you want it to do that's different? What have you tried to change to make it work?
Frankly that code has way too many #ifdefs and commented out lines in there for me to even try to make sense of it without a lot more information.
Steve
I've never made any change to the code, it supposed to process the sound of the guitar and make the motor, I'm not good at explaining things but here is the project
The devoleper asked me to tweak the code to work with my motor here is this message
Yes it is 360 servo, is there any way I can contact you directly, I really need to get this done asap xd
I recommend that you NOT attempt to tweak the code for your motor.
You are starting with sometime you do not understand and does not work, and hoping to make some small change to it and magically have it start working.
Instead, start with small goals. Go load up the servo sweep tutorial. Change the pin number to whatever number your servo is attached to. Run the sketch and see the servo move.
This way you know that you understand the use of servos in code, and that you have things wired up correctly.
Do the same for the other components of your ultimate project. Make small goals that can be tested individually.
It sounds like you are late on a homework assignment. Most forum members are painfully unconcerned with your lack of preparedness. Leave that out of the conversation and work on defining small, achievable goals.
It took you 9 days to reply to my message. That doesn't sound very urgent to me. Keep it to the forum, that way other people can also try to help.
And you still haven't said what the code does when you run it and so what sort of changes you think you need to make. I notice from that Issue that the developer only said "You MIGHT have to tweak the code". You need to do some testing to find out.
Steve
I have studied the sweep and knob motor and I know how that works. It's for my final year project
Sorry it took me 9 days but we're fasting :confused:
The code here is I need to understand how it work and how I can tweak it
I wanna ask what is the baud rate of Oppo f9, the devoleper use Samsung S4 mini which is Bluetooth version 4.0 rather than my Oppo which is version 4.2, I tried google but cant get a correct answer
// Motor
#else
#endif
That bit of code seems to be setting the range of commands to the servo, either in microseconds (1300 to 1700, stop point 1500) or in angles (76 to 112, stop point 94). You may need to modify those numbers so that your servo stops correctly and moves with the correct direction and speed when needed. Since you still haven't answered my questions about what the code does now that's all I can tell.
I have no idea what "Oppo f9" means so you're on your own there.
Steve
