Sorry I am a beginner, I am looking for the possibility to connect the HC-05 bluetooth module to the phone (android) automatically when it is in range.
I also want to make an app (via Kodular / MIT App) to turn my motorbike on / off via the app after the phone automatically connects to the HC-05 and shuts down when out of range.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
ghibran:
The range at which the HC05 will be detected will be vary significantly depending on circumstances such as local obstructions (eg other people, trees or walls) and the orientation of the devices relative to each other.
Even if the connection range was very easily determined your should NOT UNDER ANY CIRCUMSTANCES build a system that shuts off the motor bike automatically.
Small motor boats usually have the driver connected to the boat with a kill-cord so that the boat motor will switch off if the driver falls out of the boat. A similar system for a motor bike might be justified for those rare situations where the rider falls off the bike. But there should be no system that automatically shuts down the motor while the rider is in control of it.
