I have a RF remote control i want to trigger via an output on an arduino UNO!!
Hey, I have a question? I have a RF remote control i want to trigger via an output on an arduino UNO
The thing is that i only want a 1 second puls when i trigger the input button,
even if i hold the button for a long time (several seconds) on my arduino!
Each button press on the arduino unit should create a 1 second long pulse on the output.
Can someone help me? the code below almost works, but I have to reset my arduino device to trigger
the output again.
int led_pin = 11; // INDICATOR LED
int tx_pin = 10; // TX REMOTE
int button_pin = 2;
int alreadyBlinked = 0;
pinMode(led_pin, OUTPUT);
pinMode(tx_pin, OUTPUT);
pinMode(button_pin, INPUT);
int button_state = digitalRead(button_pin);
if(alreadyBlinked == 0)
if (button_state == HIGH) {
digitalWrite(led_pin, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(tx_pin, HIGH); // turn the TX on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led_pin, LOW); // turn the LED off by making the voltage LOW
digitalWrite(tx_pin, LOW); // turn the TX off by making the voltage LOW
alreadyBlinked = 1;
I see where you set alreadyBlinked = 1. When is it ever set back to 0?
Also you're going to need to work on the button BECOMING pressed not just it being in the pressed state. Have a look at the StateChangeDetection example in the IDE.
Steve
This is happening now, the LED turns on for one second and the LED goes out.
To trigger the LED agan i have to reset arduino to make it possible to press the button again to create a new pulse?!
A short or long button press on the arduino, would only send ONE one-second puls to the LED / TX module.
This works :slight_smile:
Thanks holdingpattern!!!!
holdingpattern:
Sketch below inhibits the button during the pulse. And it's all delay()-less so the code's not blocked from doing any other stuff you may want to do.
// https://forum.arduino.cc/index.php?topic=670044
// 11 mar 2020
// 1s pulse regardless of how long button is pressed
  BASED ON State change detection (edge detection) changed for INPUT PULLUP
              (button wired from pin to ground)
  https://www.arduino.cc/en/Tutorial/StateChangeDetection
// this constant won't change:
const byte  button = 2;
const byte led_pin = 11;
// Variables will change:
bool buttonState;        // current state of the button
bool lastButtonState;    // previous state of the button
bool alreadyBlinked = false;
unsigned long blinkStartedAt;
  // initialize serial communication:
  Serial.println("template");
  pinMode(button, INPUT_PULLUP);
//initialize button states
  buttonState = digitalRead(button);
  lastButtonState = buttonState;
Serial.println(" ");
  Serial.println("setup() done... press the button");
  // read the button:
// compare the buttonState to its previous state
  if (!alreadyBlinked && buttonState == LOW && lastButtonState == HIGH)
    Serial.print("New press");
    alreadyBlinked = true;
    blinkStartedAt = millis();
  }// change to low
// Delay a little bit to avoid bouncing
  delay(50);
// save the current state as the last state, for next time through the loop
if (alreadyBlinked && millis() - blinkStartedAt >= 1000)
} //loop
