I have an error message saying that its having an error compiling
#include <SparkFun_APDS9960.h>
#include "Wire.h"
#define INT_PIN  // We'll connect the INT pin from our sensor to the
                  // INT0 interrupt pin on the Arduino.
bool lightIntHappened = false; // flag set in the interrupt to let the
                  //  mainline code know that an interrupt occurred.
  //SerialUSB.begin(9600);
  Wire.begin();
  Serial.print("Starting");
  // APDS9301 sensor setup.
  //apds.begin(0x39);  // We're assuming you haven't changed the I2C
                     //  address from the default by soldering the
                     //  jumper on the back of the board.
  //apds.setGain(APDS9301::LOW_GAIN); // Set the gain to low. Strictly
                     //  speaking, this isn't necessary, as the gain
                     //  defaults to low.
  //apds.setIntegrationTime(APDS9301::INT_TIME_13_7_MS); // Set the
                     //  integration time to the shortest interval.
                     //  Again, not strictly necessary, as this is
                     //  the default.
  //apds.setLowThreshold(0); // Sets the low threshold to 0, effectively
                     //  disabling the low side interrupt.
  //apds.setHighThreshold(50); // Sets the high threshold to 500. This
                     //  is an arbitrary number I pulled out of thin
                     //  air for purposes of the example. When the CH0
                     //  reading exceeds this level, an interrupt will
                     //  be issued on the INT pin.
  //apds.setCyclesForInterrupt(1); // A single reading in the threshold
                     //  range will cause an interrupt to trigger.
  //apds.enableInterrupt(APDS9301::INT_ON); // Enable the interrupt.
  //apds.clearIntFlag();
  // Interrupt setup
(  pinMode.INT_PIN INPUT_PULLUP); // This pin must be a pullup or have
                     //  a pullup resistor on it as the interrupt is a
                     //  negative going open-collector type output.
  attachInterrupt(digitalPinToInterrupt( ), lightInt, FALLING);
 Serial.print("Every second");
  static unsigned long outLoopTimer = 1000;
  // This is a once-per-second timer that calculates and prints off
  //  the current lux reading.
  if (millis() - outLoopTimer >= 1000)
    outLoopTimer = millis();
    //SerialUSB.print("Luminous flux: ");
    //SerialUSB.println(apds.readLuxLevel(),6);
    if (lightIntHappened)
      //SerialUSB.println("Interrupt");
void lightInt()
  lightIntHappened = true;
That is my code and it keeps saying that it has an error compiling for board Arduino/Genuino Uno, and I have tried many things to solve this problem yet I cant seem to find a solution
Arduino: 1.6.11 (Windows 7), Board: "Arduino/Genuino Uno"
In file included from sketch\sketch_mar30a.ino.cpp:1:0:
D:\Arduino\sketch_mar30a\sketch_mar30a.ino: In function 'void setup()':
D:\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:45:22: error: expected unqualified-id before numeric constant
#define INPUT_PULLUP 0x2
D:\Arduino\sketch_mar30a\sketch_mar30a.ino:44:20: note: in expansion of macro 'INPUT_PULLUP'
D:\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:45:22: error: expected ')' before numeric constant
In file included from D:\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:249:0,
D:\Arduino\hardware\arduino\avr\variants\standard/pins_arduino.h:79:38: error: expected primary-expression before ')' token
#define digitalPinToInterrupt(p)  ((p) == 2 ? 0 : ((p) == 3 ? 1 : NOT_AN_INTERRUPT))
D:\Arduino\sketch_mar30a\sketch_mar30a.ino:48:19: note: in expansion of macro 'digitalPinToInterrupt'
D:\Arduino\hardware\arduino\avr\variants\standard/pins_arduino.h:79:54: error: expected primary-expression before ')' token
exit status 1
Error compiling for board Arduino/Genuino Uno.
exit status 1
option enabled in File -> Preferences.
And that is my error message
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
When your code requires a library that's not included with the Arduino IDE please always post a link (using the chain link icon on the toolbar to make it clickable) to where you downloaded that library from or if you installed it using Library Manger(Sketch > Include Library > Manage Libraries) then say so and state the full name of the library.
INT_PIN has no value, pinMode needs a (, and you need.one of these ','.
If in doubt, refer to the examples.
Which pin do you want for the interrupt?
Well, be sure to pick just one.
Edit: someone just removed a post before this reply. Please don't do that again.
Try:
#define INT_PIN 2 // INT0
outsider:
Try:
Thank you so much, that helped my teams code and we were finally able to verify it an upload it without any problems. :slight_smile:
