#include <ESP32Servo.h>
#define TRIG_PIN 23 // ESP32 pin GPIO23 connected to Ultrasonic Sensor's TRIG pin
#define ECHO_PIN 19 // ESP32 pin GPIO19 connected to Ultrasonic Sensor's ECHO pin
#define SERVO_PIN1 26 // ESP32 pin GPIO26 connected to Servo Motor's pin
#define SERVO_PIN2 27 // ESP32 pin GPIO27 connected to Servo Motor's pin
#define DISTANCE_THRESHOLD 50 // centimeters
Servo servotop; // create servo object to control a servo
Servo servobot; // create servo object to control a servo
// variables will change:
float duration_us, distance_cm;
Serial.begin (9600); // initialize serial port
pinMode(TRIG_PIN, OUTPUT); // set ESP32 pin to output mode
pinMode(ECHO_PIN, INPUT); // set ESP32 pin to input mode
servotop.attach(SERVO_PIN1); // attaches the servo on pin 26 to the servo object
servotop.write(0);
servobot.attach(SERVO_PIN2); // attaches the servo on pin 27 to the servo object
servobot.write(90);
// generate 10-microsecond pulse to TRIG pin
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(1000);
digitalWrite(TRIG_PIN, LOW);
// measure duration of pulse from ECHO pin
duration_us = pulseIn(ECHO_PIN, HIGH);
// calculate the distance
distance_cm = 0.017 * duration_us;
if (distance_cm < DISTANCE_THRESHOLD)
servotop.write(90); // rotate servo motor to 90 degree
servotop.write(0); // rotate servo motor to 0 degree
servobot.write(90); // rotate servo motor to 90 degree
servobot.write(0); // rotate servo motor to 0 degree
// print the value to Serial Monitor
Serial.print("distance: ");
Serial.print(distance_cm);
Serial.println(" cm");
Please show your best effort on separating the codes.
Just quite can't get my head around it. I'm fairly new to this.
It's taken me a whle to get my head around what I have managed so far. There seems to be loads of ways to achieve same thing.
I'm not asking for finished code just some pointers.
The number can be considered as infinity. Carry on!
This is my best effort so far. I feel like I'm so close but.
ESP32 with HC-SR04 - with a trigger distance of <10 CM sending to second ESP32 with a servo. If distance <10cm on Initiator, servo moves 90 degrees and back to 0 degrees on responder.
//HC-SR04 - output Initiator
#include <WiFi.h>
#include <esp_now.h>
#define ECHO_PIN 19 // ESP32 pin GPIO22 connected to Ultrasonic Sensor's ECHO pin
#define DISTANCE_THRESHOLD 10 // centimeters
// Responder MAC Address (Replace with your responders MAC Address)
uint8_t broadcastAddress[] = {0x88, 0x13, 0xbf, 0xdf, 0x15, 0x20};
// Define data structure
typedef struct struct_message {
float a;
float b;
} struct_message;
// Create structured data object
struct_message myData;
// Register peer
esp_now_peer_info_t peerInfo;
// Sent data callback function
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
Serial.print("Last Packet Send Status: ");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
// Setup Serial monitor
// Set ESP32 WiFi mode to Station temporarly
WiFi.mode(WIFI_STA);
// Initialize ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Error initializing ESP-NOW");
return;
// Define callback
esp_now_register_send_cb(OnDataSent);
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
Serial.println("Failed to add peer");
return;
// Add to structured data object
myData.a = duration_us, distance_cm;
myData.b = duration_us, distance_cm;
//servo 90 to 0 by sensor Responder
#include <WiFi.h>
#define SERVO_PIN 26 // ESP32 pin GPIO26 connected to Servo Motor's pin
#define DISTANCE_THRESHOLD 100 // centimeters
Servo servo; // create servo object to control a servo
float a;
float b;
} struct_message;
// Callback function
void OnDataRecv(const uint8_t * mac_addr, const uint8_t * data, int len)
// Get incoming data
memcpy(&myData, data, sizeof(myData));
if (myData.a < DISTANCE_THRESHOLD)
servo.write(90); // rotate servo motor to 90 degree
servo.write(0); // rotate servo motor to 0 degree
Serial.println(myData.a);
Serial.println("");
// Set up Serial Monitor
// Start ESP32 in Station mode
// Initilize ESP-NOW
if (esp_now_init() != ESP_OK) {
return;
// Register callback function
esp_now_register_recv_cb(OnDataRecv);
Hi! Welcome to the Forum.
Something looks odd...
I´m not seeing a function to send the data on your "initiator" sketch.
Thanks for the welcome.
I managed to get sensor and servo working on one ESP32 but wanted to split them using eps_now.
I posted my code and asked for help, b707 requested my best efforts, so that's what I have done. I'm new to this and just looking for some help and guidance if available.
Ok!
Try this sketch on the sender:
#include <WiFi.h>
float a;
float b;
} struct_message;
// Register peer
return;
// Define callback
return;
myData.a = distance_cm; //line changed
myData.b = duration_us; //line changed
esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData)); //line added
Sorry for the delay (shoulder surgery).
Thanks for the updated initiator code! I can now see the required information (distance in cm) being sent/received in the serial monitor on both initiator and responder.
I have the following bit of code on the responder bit it is not triggering the servo.
What else do need for it to work?
The only thing that comes to my mind is that you set on the receiver:
However, in the sender you have:
What is the correct distance threshold?
The distance I have settled on is 50cm. I will set the same on both send and receive and give it a go. I thought it would pick the value up from my data.a and be less then the DISTANCE_THRESHOLD on the responder.
Steep learning curve for me and appreciate your help and time so much. Thank you.
Actually, the threshold distance definition on the sender is useless, because you're not using DISTANCE_THRESHOLD anywhere else on the sender code.
This is what's expected to happen. How's the behaviour of the servo now?
No movement from the servo.
Both DISTANCE_THRESHOLD are set to the same value.
It's working!!!!
I missed out a couple of lines on the responder under
servo.attach(SERVO_PIN); //attach servo on pin
servo.write(0);
Thank you so much again for your help!!!!
