I also asked this question at the Visualmicro forum!
I have been using Mega2560 until now, but now I changing to Due.
When I compile it complains about this:
Severity Code Description Project File Line
Error 122:18: error: 'time_t' has a previous declaration as 'typedef long int time_t c:\users\matz\appdata\roaming\arduino15\packages\arduino\tools\arm-none-eabi-gcc
\4.8.3-2014q1\arm-none-eabi\include\sys\types.h 122
It seems that time_t does not like to be re declared. Anyone know how to fix this?
The Mega2560 was used until now in my project. Today I am start testing Due board instead. I using Visualmicro in VS2015. My hope was/is that the Due using the same libraries as the Mega2560 so the transition to Due will be easy.
I installed the Due and tried to compile. The compiler gave me the error about the re-declaration. I read that this was a known problem, but I did not really find any solution. One solution was to install a new library, but I read that it was different problem with the library, MarkusLange/Arduino-Due-RTC-Library.
Any one tested that library?
Any one knows about any other differences regarding libraries or other problem?
And what can I do to fix the error about the re-declaration, is it to use another RTC library?
Oh, dear. Starting with an unrealistic expectation is never a good thing.
Some code that we still haven't seen.
I've read lots of nonsense on the internet. I've failed to find solutions to problems, too. But, then I don't often post "It doesn't work" type threads without a boatload more information than you've provided so far.
I told you. Stop making a duplicate declaration.
If you need help with that, you really must tell us what library is causing you problems. There just is no other way.
Serial.begin(4800);
Serial.write(highByte(port));
Serial.write(lowByte(port));
for(unsigned int i = 0; i<4 ;i++){
Serial.write(ip*);*
}* } void loop() {
draw(); * } void draw(void){
u8g.firstPage();*
u8g.setColorIndex(3);*
do{*
u8g.setFont(u8g_font_8x13B);*
u8g.drawStr(3,15,"Set Up complete");*
u8g.drawStr(5,30,"IP: "); *
u8g.drawStr(7,45, "Port: ");*
u8g.setFont(u8g_font_6x12r);*
u8g.setPrintPos(30,30);*
u8g.print(ip);*
u8g.setPrintPos(50,45);*
u8g.print(port);*
}while( u8g.nextPage() );*
delay(200);* } With the Due it complains about the re-declaration, I don't like that, it is bad! I wonder if I missed something obvious or can I expect more of these types of errors when I fix this one??? The two declarations were at ICMPPing and in c:\users\matz\appdata\roaming\arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1\arm-none-eabi\include\sys\types.h. I renamed the one in ICMPPing from time_t to ltime_t (typedef unsigned long ltime_t;). Now it does not complain about that, now it is new errors. Regards
