For well-informed help, please read and follow the instructions in the "How to get the best out of the forum" linked at the head of every forum category.
I think you are supposed to pass the TCP/IP Client to the HTTPClient::begin() function, along with the URL. I don't see where you created a GSM Client.
thank for your reply sir ,
this was just a part of my code and I have created GSM client. I would like to share my full code with you. I have just deleted the google script id.
#define SIM800L_IP5306_VERSION_20200811
#include "GPRS.h"
#include <WiFi.h>
#include <Wire.h>
#include <TinyGPS++.h>
#include "utilities.h"
#include <HTTPClient.h>
#include "DHT.h"
#define pi 3.14159265358979323846
#define RXD2 14
#define TXD2 12
#define DHTPIN 4
#define LDR 34
#define DHTTYPE DHT22
//#define SIM800L_IP5306_VERSION_20200811
HardwareSerial neogps(1);
#define SerialMon Serial
#define SerialAT Serial1
TinyGsmClient client(modem);
float h1=0;
float t1=0;
double latt1;
double lang1;
double latt;
double lang;
int dark1=100;
const char server[] = "script.google.com";
String GAS_ID = "AKfycbxYRm_5hcILyQoXRVhNkLKfulwUG7J93d6miH_rEE7qkFjQsT60Zgv8deS1NCqDb742";
TinyGPSPlus gps;
String GOOGLE_SCRIPT_ID = "AKfycbxYRm_5hcILyQoXRVhNkLKfulwUG7J93d6miH_rEE7qkFjQsT60Zgv8deS1NCqDb742"; // Type your App Script id
const int port = 80;
DHT dht(DHTPIN, DHTTYPE);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo native USB port only
Serial.println(F("DHTxx test!"));
dht.begin();
neogps.begin(9600, SERIAL_8N1, RXD2, TXD2);
// This function call sets up the module but in a blocking matter!
GPRS_wake_up();
// If you have other modules to set up, you can call GPRS_init()
// in a conditional loop and put other modules to setup with it
// since it actually uses millis() to time its steps, not delays!
/* do{
GPRS_init();
Other_module_init();
}while(gprs_setup_state != GPRS_READY_
&& not(Other_module_ready_condition)
if(GPRS_connectivity_status())
Serial.println("Connected to cellular network!");
float dark ;
int ldr = analogRead(LDR) ;
dark= map(ldr,0,4095,0,100);
Serial.println(dark);
delay (1000);
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true);
if (isnan(h) || isnan(t) || isnan(f))
Serial.println(F("Failed to read from DHT sensor!"));
//return ;
Serial.println(h);
Serial.println(t);
/// function to get lat long .
boolean newData = false;
for (unsigned long start = millis(); millis() - start < 1000;)
while (neogps.available())
if (gps.encode(neogps.read()))
newData = true;
//If newData is true
if(newData == true)
newData = false;
latt =(gps.location.lat());
lang =(gps.location.lng());
//double sat=gps.satellites.value();
//Serial.print(latt);
Serial.println(gps.satellites.value());
Serial.println(gps.location.lng(),15);
Serial.println(gps.location.lat(),15);
Serial.println("no data");
if(latt==0 && lang ==0)
//latt=latt1;
//lang=lang1;
//double d= distance(latt1,lang1,latt,lang);
//if((abs(h-h1)>=2) || (abs (t-t1)>=.5))//||(abs(d)>=1) || abs(dark-dark1)>=10 )
Serial.print(F("Temperature "));
Serial.print(t);
Serial.println(F("°C "));
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.println(F("%"));
t1=t;
h1=h;
latt1=latt;
lang1=lang;
dark1=dark;
// for writting in google sheet
write_google_sheet( "value1="+ String(t)+"&value2="+String(h)+"&value3="+String(latt)+"&value4="+String(lang)+"&value5="+String(dark));
/* SerialMon.print("Connecting to ");
SerialMon.print(server);
if (!client.connect(server, port)) {
SerialMon.println(" fail");
delay(10000);
return;
SerialMon.println(" OK");
String url = "/macros/s/" + GAS_ID + "/exec?value1=" + String(5)+ "&value2=" + String(8);
// Make a HTTP GET request:
SerialMon.println("Performing HTTP GET request...");
client.print(String("GET ") + url + " HTTP/1.1\r\n");
client.print(String("Host: ") + server + "\r\n");
client.print("Connection: close\r\n\r\n");
client.println();
unsigned long timeout = millis();
while (client.connected() && millis() - timeout < 10000L) {
// Print available data
while (client.available()) {
char c = client.read();
SerialMon.print(c);
timeout = millis();
SerialMon.println();
// Shutdown
client.stop();
SerialMon.println(F("Server disconnected"));
//modem.gprsDisconnect();
//SerialMon.println(F("GPRS disconnected"));
Serial.println("not connected");
double deg2rad(double);
double rad2deg(double);
double distance(double lat1, double lon1, double lat2, double lon2) {
double theta, dist;
if ((lat1 == lat2) && (lon1 == lon2)) {
return 0;
else {
theta = lon1 - lon2;
dist = sin(deg2rad(lat1)) * sin(deg2rad(lat2)) + cos(deg2rad(lat1)) * cos(deg2rad(lat2)) * cos(deg2rad(theta));
dist = acos(dist);
dist = rad2deg(dist);
dist = dist * 60 * 1.1515;
dist = dist * 1.609344;
return (dist);
/*:: This function converts decimal degrees to radians :*/
double deg2rad(double deg) {
return (deg * pi / 180);
/*:: This function converts radians to decimal degrees :*/
double rad2deg(double rad) {
return (rad * 180 / pi);
void write_google_sheet(String params) {
HTTPClient http;
String url="https://script.google.com/macros/s/"+GOOGLE_SCRIPT_ID+"/exec?"+params;
Serial.println(url);
//Serial.println("Updating Temperature & Humidity Status");
http.begin(url.c_str());
http.setFollowRedirects(HTTPC_STRICT_FOLLOW_REDIRECTS);
int httpCode = http.GET();
Serial.print("HTTP Status Code: ");
Serial.println(httpCode);
String payload;
if (httpCode > 0) {
payload = http.getString();
Serial.println("Payload: "+payload);
http.end();
delay(10000);
return;
client.println();
SerialMon.print(c);
timeout = millis();
// Shutdown
client.stop();
// GPRS.h
////GSM module specification
#define TINY_GSM_MODEM_SIM800
#include <TinyGsmClient.h> //https://github.com/vshymanskyy/TinyGSM
//#include "GPRS.h"
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWRKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
#define MODEM_BAUD_RATE 115200 //115.2 Kb/s baud rate
// GPRS init states
#define GPRS_RESET 0
#define GPRS_START_SERIAL 1
#define GPRS_INIT_MODULE 2
#define GPRS_INIT_MODEM 3
#define GPRS_CONNECT 4
#define GPRS_READY_ 5
// GPRS data
#define GPRS_USER ""
#define GPRS_PASS ""
#define APN "airtelgprs.com" // APN (google the apn of your network provider in your country)
#define SIM_PIN "" // If SIM is locked, provide the PUK code
// Timeout connection before automatically restarting
#define GPRS_CONN_TIMEOUT 10000UL // 10 seconds
// Hardware Serial for builtin GSM Module
#define SerialAT Serial1 //I'm using an esp32, which have 3 hardware serial ports, i'm using the 2nd for the modem !
void setup_modem();
void GPRS_init();
void GPRS_wake_up();
void GPRS_put_to_sleep();
bool GPRS_connectivity_status();
/// cpp
TinyGsm modem(SerialAT);
// Setup variables
unsigned long GPRS_last_update = 0;
int gprs_setup_state = 0;
bool serial_ready = false;
bool module_ready = false;
bool connect_ready = false;
// Functions' declarations
void GPRS_init(){
switch(gprs_setup_state){
case GPRS_RESET:{
gprs_setup_state = GPRS_START_SERIAL;
GPRS_last_update = millis();
case GPRS_START_SERIAL:{
if(!serial_ready) {
serial_ready = true;
SerialAT.begin(MODEM_BAUD_RATE, SERIAL_8N1, MODEM_RX, MODEM_TX);
if(millis() - GPRS_last_update >= 100){
gprs_setup_state = GPRS_INIT_MODULE;
case GPRS_INIT_MODULE:{
if(!module_ready) {
module_ready = true;
setup_modem();
if(millis() - GPRS_last_update >= 3000){
gprs_setup_state = GPRS_INIT_MODEM;
case GPRS_INIT_MODEM:{
modem.restart();
gprs_setup_state = GPRS_CONNECT;
case GPRS_CONNECT:{
if(!connect_ready) {
connect_ready = true;
// Unlock SIM if PIN is required (;provided)
if (SIM_PIN && modem.getSimStatus() != 3 ) {
modem.simUnlock(SIM_PIN);
// Connect
modem.gprsConnect(APN, GPRS_USER, GPRS_PASS);
if(millis() - GPRS_last_update >= 500){
gprs_setup_state = GPRS_READY_;
case GPRS_READY_:{
default: break;
// Please refer to the datasheet of the SIM800 for more details about this process
void setup_modem(){
pinMode(MODEM_RST, OUTPUT);
digitalWrite(MODEM_RST, HIGH);
pinMode(MODEM_PWRKEY, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_POWER_ON, HIGH);
// Pull down PWRKEY for 1 second or more according to manual requirements
digitalWrite(MODEM_PWRKEY, HIGH);
delay(10);
digitalWrite(MODEM_PWRKEY, LOW);
void GPRS_put_to_sleep(){
SerialAT.write("AT+CSCLK=2\r"); // Enable sleep mode until external interrupt
// Consult datasheet: https://www.elecrow.com/download/SIM800%20Series_AT%20Command%20Manual_V1.09.pdf
// (Page 160, AT+CSCLK Configure Slow Clock)
void GPRS_wake_up(){
unsigned long started_init_ = millis();
do{
GPRS_init();
&& (millis() - started_init_ <= GPRS_CONN_TIMEOUT));
if(!modem.isGprsConnected()){ // Couldn't connect
ESP.restart();
bool GPRS_connectivity_status(){
return modem.isGprsConnected();
So compare your sketch to the example sketch to see if you are doing anything differently. Or start over with the HttpClient example and build your sketch on that. Make sure you test often so you can detect a failure early.
