I am new to Arduino and C programming. I have been getting a “Low memory available, stability problems may occur. Sketch uses 12,394 bytes and Global uses 1,913 bytes. What changes to the program lines are needed?
I am using an Ardunio Uno R3
SortingHat1.ino (5.06 KB)
system
January 9, 2016, 9:10pm
#2
Just POST the code
#include <PGMWrap.h>
#include <Brain.h>
#include <ArduinoPins.h>
#include <FatReader.h>
#include <FatStructs.h>
#include <mcpDac.h>
#include <SdInfo.h>
#include <SdReader.h>
#include <WaveHC.h>
#include <Wavemainpage.h>
#include <WavePinDefs.h>
#include <WaveUtil.h>
// Set up the brain reader, pass it the hardware serial object you want to listen on.
Brain brain(Serial);
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
FatReader file; // This object represent the WAV file
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
long interval = 0;
int hse = 0;
Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
//////////////////////////////////// SETUP
if (!card.init()) error("card.init");
// enable optimized read - some cards may timeout
card.partialBlockRead(true);
if (!vol.init(card)) error("vol.init");
if (!root.openRoot(vol)) error("openRoot");
//playGriffin();
//playHuffle();
//playRaven();
//playSlith();
//playTnk1();
//playTnk2();
//playTryAgain();
//////////////////////////////////// LOOP
brain.update();
// Make sure we have a signal.
int signalQual = brain.readSignalQuality();
Serial.println(signalQual);
if (signalQual < 50) {
askAbouthses();
void askAbouthses() {
playTnk2();
playAskGriffin();
playAskHuffle();
playAskRaven();
playAskSlith();
playTnk1();
makeDecision();
delay(10000);
void readMind(int hseIndex) {
if (brain.update()) {
if (hseIndex != 0) {
int currInterval = brain.readAttention();
if (currInterval > interval) {
interval = currInterval;
hse = hseIndex;
void makeDecision() {
if (hse == 1) {
playGriffin();
else if (hse == 2) {
playHuffle();
else if (hse == 3) {
playRaven();
else if (hse == 4) {
playSlith();
hse = 0;
interval = 0;
/////////////////////////////////// HELPERS
print error message and halt
void error_P(const char *str) {
PgmPrint("Error: ");
SerialPrint_P(str);
sdErrorCheck();
while (1);
print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
if (!card.errorCode()) return;
PgmPrint("\r\nSD I/O error: ");
Serial.print(card.errorCode(), HEX);
PgmPrint(", ");
Serial.println(card.errorData(), HEX);
while (1);
Play the Griffin Audio Clip
void playGriffin(void) {
char name[10];
// copy flash string to RAM
strcpy_P(name, PSTR("DTMF0.WAV"));
playSound(name, 4100, 0);
Play the Ask Griffin Audio Clip
void playAskGriffin(void) {
char name[10];
strcpy_P(name, PSTR("DTMF7.WAV"));
playSound(name, 4100, 1);
Play the Huffle Audio Clip
void playHuffle(void) {
char name[10];
strcpy_P(name, PSTR("DTMF1.WAV"));
Play the Ask Huffle Audio Clip
void playAskHuffle(void) {
char name[10];
strcpy_P(name, PSTR("DTMF8.WAV"));
playSound(name, 4100, 2);
Play the Raven Audio Clip
void playRaven(void) {
char name[10];
strcpy_P(name, PSTR("DTMF2.WAV"));
playSound(name, 1500, 0);
Play the Ask Raven Audio Clip
void playAskRaven(void) {
char name[10];
strcpy_P(name, PSTR("DTMF9.WAV"));
playSound(name, 5100, 3);
Play the Slith Audio Clip
void playSlith(void) {
char name[10];
strcpy_P(name, PSTR("DTMF3.WAV"));
playSound(name, 2100, 0);
Play the Ask Slith Audio Clip
void playAskSlith(void) {
char name[10];
strcpy_P(name, PSTR("DTMF10.WAV"));
playSound(name, 4500, 4);
Play the Tnk1 Audio Clip
void playTnk1(void) {
char name[10];
strcpy_P(name, PSTR("DTMF4.WAV"));
playSound(name, 7100, 0);
Play the Tnk2 Audio Clip
void playTnk2(void) {
char name[10];
strcpy_P(name, PSTR("DTMF5.WAV"));
playSound(name, 19100, 0);
Play the TryAgain Audio Clip
void playTryAgain(void) {
char name[10];
strcpy_P(name, PSTR("DTMF6.WAV"));
playSound(name, 10100, 0);
Play whatever sound file name is passed through, for the duration specified in milliseconds
void playSound(char* name, int millisecs, int hseIndex) {
// start time
uint32_t t = millis();
// open file by name
if (!file.open(root, name)) error("open by name");
// create wave and start play
if (!wave.create(file))error("wave.create");
wave.play();
// stop after PLAY_TIME ms
while ((millis() - t) < millisecs) {
readMind(hseIndex);
wave.stop();
// check for play errors
sdErrorCheck();
PgmPrintln("Done");
It looks like you are using almost all of your RAM in your sketch. Combined with the bootloader your program is most likely using as much or more RAM than your Arduino actually has. I suggest reducing the RAM usage as much as possible in your sketch.
DrAzzy
January 9, 2016, 9:36pm
#4
I see no flagrant wastes of ram there. I think it's the libraries doing it, and it looks like you need them....
I think you might want to consider a mega2560 or 1284p based board.
Will the 2560 accept the Adafruit Wave Shield for Arduino.
Since I may not be able to use the 2560 with the wave shield, would you suggest what lines in the code I need to change and to what?
Check if all ints need 16 bits, maybe uint8_t is adequate.
you have a dozen functions with the same pattern, e.g
char name[10];
Put the WAV strings in a PROGMEM array and you can handle it with one function with the index as param.
(OK would only save some flash)
possibly just add param to playSound would work.
remove some error handling ?
Thank you. To show my ignorance further I can use some help in setting up the PROGMEM array.
