I have problem on programming Relay and LCD
Hi ,
I have problem on programming LCD when the relay turns on or off the display doesn't show any thing but when i use display examples it works fine .
here is my sketch :
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int thisChar1 = 'LIGHT ON';
int thisChar2 = 'LIGHT OFF';
const int REL = 8;
lcd.begin(16, 2);
pinMode(REL, OUTPUT);
digitalWrite(REL, HIGH);
delay(60000);
digitalWrite(REL, LOW);
delay(62000);
if (REL == HIGH)
lcd.print(thisChar1);
if (REL == LOW)
lcd.print(thisChar2);
i hope you can help me .
if (REL == HIGH)
8 is not going to equal 1 any time soon.
if (REL == LOW)
Or zero, for that matter.
Please get used to using code tags when posting code.
sorry , but i am beginner in coding of arduino .
so what the code should be like when i want to display ON/OFF in this conditions.
You absolutely know when and what you wrote to the relay, so why are you testing anything?
What are you trying to do?
That won't give you a compilation error, but it isn't remotely correct.
i am trying to make a 2 hour timer with 2 relay and LCD but i test on one now with this code :
#define RELAY1 3
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
int runTimer = 1;
int runFor = 60;
int data = 0;
lcd.begin(16, 2);
pinMode(RELAY1, OUTPUT);
if(runTimer == 1){
digitalWrite(RELAY1, HIGH);
lcd.setCursor(0,1);
lcd.print("LIGHT ON");
timer();
else {
digitalWrite(RELAY1, LOW);
lcd.setCursor(0,0);
lcd.print("LIHGHT OFF");
runTimer = 60;
void timer() {
for(int timer = runFor;timer > 0; --timer){
if(timer >= 10) {
lcd.setCursor(6,0);
lcd.setCursor(7,0);
lcd.print(" ");
lcd.setCursor(6,0);
lcd.print(timer);
lcd.setCursor(0,0);
lcd.print("Sec : ");
lcd.clear();
but this count down for 60s and doesnt playpack again what i want to make is in the first 2 hour the first relay begin after the 2 hour gone the second relay start and the LCD display if the two relays are ON/OFF whic i plan to use it in a project .
