#include <avr/interrupt.h>
#include "WConstants.h"
#include "AFSoftSerial.h"
- Definitions
#define AFSS_MAX_RX_BUFF 64
- Statics
static uint8_t _receivePin;
static uint8_t _transmitPin;
static int _bitDelay;
static char _receive_buffer[AFSS_MAX_RX_BUFF];
static uint8_t _receive_buffer_index;
#if (F_CPU == 16000000)
void whackDelay(uint16_t delay) {
uint8_t tmp=0;
asm volatile("sbiw %0, 0x01 \n\t"
"ldi %1, 0xFF \n\t"
"cpi %A0, 0xFF \n\t"
"cpc %B0, %1 \n\t"
"brne .-10 \n\t"
: "+r" (delay), "+a" (tmp)
: "0" (delay)
#endif
- Interrupts
SIGNAL(SIG_PIN_CHANGE0) {
if ((_receivePin >=8) && (_receivePin <= 13)) {
recv();
SIGNAL(SIG_PIN_CHANGE2)
if (_receivePin <8) {
recv();
void recv(void) {
char i, d = 0;
if (digitalRead(_receivePin))
return; // not ready!
whackDelay(_bitDelay - 8);
for (i=0; i<8; i++) {
//PORTB |= _BV(5);
whackDelay(_bitDelay2 - 6); // digitalread takes some time
//PORTB &= ~_BV(5);
d |= (1 << i);
whackDelay(_bitDelay2);
if (_receive_buffer_index >= AFSS_MAX_RX_BUFF)
return;
_receive_buffer[_receive_buffer_index] = d; // save data
_receive_buffer_index++; // got a byte
- Constructors
AFSoftSerial::AFSoftSerial(uint8_t receivePin, uint8_t transmitPin)
_receivePin = receivePin;
_transmitPin = transmitPin;
_baudRate = 0;
void AFSoftSerial::setTX(uint8_t tx) {
_transmitPin = tx;
void AFSoftSerial::setRX(uint8_t rx) {
_receivePin = rx;
- User API
void AFSoftSerial::begin(long speed)
pinMode(_transmitPin, OUTPUT);
digitalWrite(_transmitPin, HIGH);
pinMode(_receivePin, INPUT);
digitalWrite(_receivePin, HIGH); // pullup!
_baudRate = speed;
switch (_baudRate) {
case 115200: // For xmit -only-!
_bitDelay = 4; break;
case 57600:
_bitDelay = 14; break;
case 38400:
_bitDelay = 24; break;
case 31250:
_bitDelay = 31; break;
case 19200:
_bitDelay = 54; break;
case 9600:
_bitDelay = 113; break;
case 4800:
_bitDelay = 232; break;
case 2400:
_bitDelay = 470; break;
default:
_bitDelay = 0;
if (_receivePin < 8) {
// a PIND pin, PCINT16-23
PCMSK2 |= _BV(_receivePin);
PCICR |= _BV(2);
} else if (_receivePin <= 13) {
// a PINB pin, PCINT0-5
PCICR |= _BV(0);
PCMSK0 |= _BV(_receivePin-8);
whackDelay(_bitDelay*2); // if we were low this establishes the end
int AFSoftSerial::read(void)
uint8_t d,i;
if (! _receive_buffer_index)
return -1;
d = _receive_buffer[0]; // grab first byte
// if we were awesome we would do some nifty queue action
// sadly, i dont care
for (i=0; i<_receive_buffer_index; i++) {
_receive_buffer = _receive_buffer[i+1];
_receive_buffer_index--;*
return d;*
uint8_t AFSoftSerial::available(void)
return _receive_buffer_index;*
void AFSoftSerial::print(uint8_t b)
if (_baudRate == 0)*
return;*
byte mask;*
cli(); // turn off interrupts for a clean txmit*
digitalWrite(_transmitPin, LOW); // startbit*
whackDelay(_bitDelay*2); -
for (mask = 0x01; mask; mask <<= 1) {*
if (b & mask){ // choose bit*
digitalWrite(_transmitPin,HIGH); // send 1*
else{*
digitalWrite(_transmitPin,LOW); // send 1*
digitalWrite(_transmitPin, HIGH);*
sei(); // turn interrupts back on. hooray!*
whackDelay(bitDelay*2);
void AFSoftSerial::print(const char *s)
_ while (*s)
_ print(*s++);_
void AFSoftSerial::print(char c)
print((uint8_t) c);*
void AFSoftSerial::print(int n)
print((long) n);*
void AFSoftSerial::print(unsigned int n)
print((unsigned long) n);*
void AFSoftSerial::print(long n)
if (n < 0) {*
print('-');*
n = -n;*
printNumber(n, 10);*
void AFSoftSerial::print(unsigned long n)
void AFSoftSerial::print(long n, int base)
if (base == 0)*
print((char) n);*
else if (base == 10)*
print(n);*
else*
printNumber(n, base);*
void AFSoftSerial::println(void)
print('\r');*
print('\n'); *
void AFSoftSerial::println(char c)
print(c);*
println(); *
void AFSoftSerial::println(const char c[])
print(c);*
println();*
void AFSoftSerial::println(uint8_t b)
print(b);*
println();*
void AFSoftSerial::println(int n)
print(n);*
println();*
void AFSoftSerial::println(long n)
print(n);*
println(); *
void AFSoftSerial::println(unsigned long n)
print(n);*
println(); *
void AFSoftSerial::println(long n, int base)
print(n, base);*
println();*
// Private Methods /////////////////////////////////////////////////////////////
void AFSoftSerial::printNumber(unsigned long n, uint8_t base)
_ unsigned char buf[8 * sizeof(long)]; // Assumes 8-bit chars._ -
unsigned long i = 0;*
if (n == 0) {*
print('0');*
return;*
while (n > 0) {*
buf[i++] = n % base;*
n /= base;*
for (; i > 0; i--)*
print((char) (buf[i - 1] < 10 ? '0' + buf[i - 1] : 'A' + buf[i - 1] - 10));*
AFSoftSerial.cpp:24:24: error: WConstants.h: No such file or directory
AFSoftSerial.cpp: In function 'void recv()':
AFSoftSerial.cpp:78: error: 'digitalRead' was not declared in this scope
AFSoftSerial.cpp:85: error: 'digitalRead' was not declared in this scope
AFSoftSerial.cpp: In member function 'void AFSoftSerial::begin(long int)':
AFSoftSerial.cpp:121: error: 'OUTPUT' was not declared in this scope
AFSoftSerial.cpp:121: error: 'pinMode' was not declared in this scope
AFSoftSerial.cpp:122: error: 'HIGH' was not declared in this scope
AFSoftSerial.cpp:122: error: 'digitalWrite' was not declared in this scope
AFSoftSerial.cpp:124: error: 'INPUT' was not declared in this scope
AFSoftSerial.cpp: In member function 'void AFSoftSerial::print(uint8_t)':
AFSoftSerial.cpp:188: error: 'byte' was not declared in this scope
AFSoftSerial.cpp:188: error: expected `;' before 'mask'
AFSoftSerial.cpp:192: error: 'LOW' was not declared in this scope
AFSoftSerial.cpp:192: error: 'digitalWrite' was not declared in this scope
AFSoftSerial.cpp:195: error: 'mask' was not declared in this scope
AFSoftSerial.cpp:197: error: 'HIGH' was not declared in this scope
AFSoftSerial.cpp:205: error: 'HIGH' was not declared in this scope
