i have problem with wifi shield
i use arduino mega 2560 r3 and Arduino Wi-Fi Shield (antenna connector) i have interface cable and antenna
i test my wifi shield with example > scan networks but have a problem my wifi shield not work (i check my wifi shield with led it work but it cant connect wifi) when i open serial monitor it away print "WiFi shield not present"
i try to fix it. i change version ide 1.0.5 to 1.0.2 but it not work
please help me
The Arduino Wifi Shield doesn't have an antenna connector so you're probably using another shield. Provide a link to the hardware you're using and post the code you use to test it. If it uses some library that is not part of the standard IDE, provide a link to it too.
@pylon: This will be a surprise. It was to me also.
The OP double posted. I'm answering him in Networking.
i use original arduino library wifi > scan networks but it away show "WiFi shield not present" in serial monitor
this is my hardware : Arduino Official Store | Boards Shields Kits Accessories
i try to change my arduino mega 2560r3 to uno r3 but it still same "WiFi shield not present"
and jumper pin 7 and 3 but it not work
Led on L9 blinking when i upload or reset shield
sorry for my english is bad
thanks for help me SurferTim :smiley:
I'm sorry, I know nothing about the new version of the shield. Maybe they have just added the antenna connector, maybe they changed other things too, difficult to tell without having more information about the new version. Have you checked the software version running on the shield using the FTDI connector?
