Now I plan to improve it and maybe learn a bit more.
The code was written to emulate (sort of) some communications code running on two serially connected (UART) arduino units which I had been working on with some considerable difficulty given that I did not know which unit was causing which problem.
My objective was to successfully transfer a structure containing both byte and float variables through a single byte interface and re-create the data successfully. This now works as intended using just the one arduino (actually a nano)
I could now move on to using this same approach on the two arduino's (one is a nano the other a mega 2560) but a helpful friend told me my approach is all wrong as I should be using pointers.
So, my question is: Should I continue with this approach or is there a far better method?
Please be gentle, my only previous experience with coding was during the 1980's using assembler.
This test code is designed to explore how an array containing both bytes and floats
can be transferred through a byte sized interface and re-constructed with the same
data format and content.
The idea is to simulate passing byte size variables over a serial link using two
arduino units
pseudo code:
fill the sending structure with dummy data
// Now pass the data via a single byte variable to represent the serial port
for(i = 0; i < totalMessageSize; i++)
transferByte = sending strucure[i];
receivingStructure[i] = transferByte;
// First define the source data
#define shortMessageSize 6
#define longMessageSize 4
#define totalMessageSize (shortMessageSize + (longMessageSize * 4) + 2)
byte dummyBytes[] = {2,4,6,8,3,3};
float dummyFloats[] = {3.141, 2.453, 56.4, 2234.5};
float tempFloat = 0;
int i;
// Construct the transmit data container
typedef struct
byte txShortMessage[shortMessageSize];
byte txShortMessageLRC;
float txLongMessage[longMessageSize];
byte txLongMessageLRC;
} txArray;
typedef union
txArray tx;
byte newArray[sizeof(txArray)];
} UTX;
UTX tx;
// Define the transfer location
byte transferByte = 0;
// Construct the receiving data container
typedef struct
byte rxShortMessage[shortMessageSize];
byte rxShortMessageLRC;
float rxLongMessage[longMessageSize];
byte rxLongMessageLRC;
} rxArray;
typedef union
rxArray rx;
byte newArray[sizeof(rxArray)];
} URX;
URX rx;
// Now populate the source array with data from dummyBytes & dummyFloats
for(i = 0; i < shortMessageSize; i++)
tx.tx.txShortMessage[i] = dummyBytes[i];
tx.tx.txShortMessageLRC = 55; // Any rubbish will do for testing
for(i = 0; i < longMessageSize; i++)
tx.tx.txLongMessage[i] = dummyFloats[i];
// Now pass the data across the invisible wire to the receiver one
// byte at a time
for(i = 0; i <= totalMessageSize; i++)
transferByte = tx.tx.txShortMessage[i];
Serial.print(transferByte,DEC); // Print the byte being transferred
rx.rx.rxShortMessage[i] = transferByte;
tempFloat = rx.rx.rxLongMessage[i];
printDouble(tempFloat, 4);
Serial.print(" ");
Serial.println("");
void printDouble( double val, byte precision)
// prints val with number of decimal places determined by precision
// precision is a number from 0 to 6 indicating the desired decimal places
// example: printDouble( 3.1415, 2); // prints 3.14 (two decimal places)
Serial.print (int(val)); //prints the int part
if( precision > 0)
Serial.print("."); // print the decimal point
unsigned long frac;
unsigned long mult = 1;
byte padding = precision -1;
while(precision--)
mult *=10;
if(val >= 0)
frac = (val - int(val)) * mult;
frac = (int(val)- val ) * mult;
unsigned long frac1 = frac;
while( frac1 /= 10 )
padding--;
while( padding--)
Serial.print("0");
Serial.print(frac,DEC) ;
