I have some problems
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jimmy\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jimmy\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jimmy\Documents\Arduino\libraries -fqbn=arduino:megaavr:uno2018:mode=off -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\jimmy\AppData\Local\Temp\arduino_build_74774 -warnings=none -build-cache C:\Users\jimmy\AppData\Local\Temp\arduino_cache_242345 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jimmy\AppData\Local\Temp\arduino_modified_sketch_64013\BareMinimum.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jimmy\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jimmy\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\jimmy\Documents\Arduino\libraries -fqbn=arduino:megaavr:uno2018:mode=off -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\jimmy\AppData\Local\Temp\arduino_build_74774 -warnings=none -build-cache C:\Users\jimmy\AppData\Local\Temp\arduino_cache_242345 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avrdude.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\jimmy\AppData\Local\Temp\arduino_modified_sketch_64013\BareMinimum.ino
Using board 'uno2018' from platform in folder: C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Using core 'arduino' from platform in folder: C:\Users\jimmy\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7
Detecting libraries used...
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\sketch\\BareMinimum.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\sketch\\BareMinimum.ino.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\sketch\\BareMinimum.ino.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\sketch\\BareMinimum.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018\\variant.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\variant.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring_pulse.S" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_pulse.S.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\hooks.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\hooks.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring_shift.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_shift.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring_analog.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_analog.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring_digital.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_digital.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\wiring_pulse.c" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_pulse.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\CDC.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\CDC.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UART3.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART3.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UART1.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART1.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\NANO_compat.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\NANO_compat.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\Tone.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\Tone.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UART2.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART2.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UART.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UART0.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART0.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\UNO_compat.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UNO_compat.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\USBCore.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\USBCore.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\WInterrupts.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\WInterrupts.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\WMath.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\WMath.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\abi.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\abi.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\main.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\main.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\new.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\new.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\Common.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Common.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\IPAddress.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\PluggableUSB.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\Print.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Print.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\Stream.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Stream.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO_WIFI_REV2 -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino/api/deprecated" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino" "-IC:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\variants\\uno2018" "C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\cores\\arduino\\api\\String.cpp" -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\String.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_pulse.S.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\hooks.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_analog.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_digital.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_pulse.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\wiring_shift.c.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\CDC.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\NANO_compat.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\Tone.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART0.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART1.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART2.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UART3.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\UNO_compat.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\USBCore.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\WInterrupts.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\WMath.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\abi.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Common.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Print.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\Stream.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\api\\String.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\main.cpp.o"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc-ar" rcs "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\core.a" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\new.cpp.o"
Archiving built core (caching) in: C:\Users\jimmy\AppData\Local\Temp\arduino_cache_242345\core\core_arduino_megaavr_uno2018_mode_off_f70529a0a1286aee320153db5a24c319.a
Linking everything together...
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x200 -mmcu=atmega4809 -o "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\sketch\\BareMinimum.ino.cpp.o" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774\\core\\variant.c.o" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/core\\core.a" "-LC:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774" -lm
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O binary -R .eeprom "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.bin"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.eep"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.elf" "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.hex"
"C:\\Users\\jimmy\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino5/bin/avr-size" -A "C:\\Users\\jimmy\\AppData\\Local\\Temp\\arduino_build_74774/BareMinimum.ino.elf"
Sketch uses 1226 bytes (2%) of program storage space. Maximum is 48640 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
An error occurred while uploading the sketch
avrdude: usbhid_open(): No device found
avrdude: jtag3_open_common(): Did not find any device matching VID 0x03eb and PID list: 0x2145
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Hi, @jwames30
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Tom... :grinning: :+1: :coffee: :australia:
Welcome jwames30, Some error outputs are machine and OS dependent. Can you get the Blink sketch to compile and work? I ask this since you know your programming is right. This will give us an idea of how your interface is working. Also did you select the correct board and port?
Your sketch compiled but is not uploaded, probably due to board not been installed correctly or connection problem
