I have the 328-PU, got the boot loader on, but now I get "not in sync"
Hello,
I have an Arduino Uno board. I programmed with the included chip, but I fried it on a breadboard application. So I bought some ATmega328-PU chips from digi-key. These did not have the bootloader on them.
I used this guide: http://forum.arduino.cc/index.php?topic=58670.0
And I was able to get the bootloader on this chip (I used ATmegaBOOT_168_atmega328.hex)
Now, I'm trying to upload code to the chip normally using the Uno, but I get the following errors:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xad
Any idea what the issue may be?
As a clarification:
  • I have tried to put a 110 resistor between RESET and 5V, and it still does not work.
  • I have tried to put a 10uF resistor between 5V and ground, and it still does not work.
  • I made sure to change 14 back to 0F in the configuration file after I got the bootloader working.
  • I have NOT verified that the Bootloader is actually working though... How would I do this?
The UNO doesn't use ATmegaBOOT_168_atmega328.hex. See boards.txt:
uno328.bootloader.path=optiboot
uno328.bootloader.file=optiboot_atmega328.hex
