I have trouble with xbee WIFI?
For two weeks, I haven't got xbee wifi to communicate with another xbee wifi, am just gonna re-send them back. They came with the same "MY" address. In the console, when I change DL from 255 to MY, it appears that both devices can transmit and send data. So first sends the data, and then receives that same data it sent, while the 2nd receives nothing even if it had the same DL and MY. Similary if I send from 2nd xbee, it will send and receive its own data in console while the 1st one receives nothing.
Did any of you get xbee wifi to work, as in communication between two xbees, what were your settings?
I also can't change the "MY" address, when I try to "write" it gives error. But DL writes properly.
I am not sure if you can communicate like that. I don't have two wifi modules to check. But two modules having the same address should create a conflict. you can try the dhcp option of xbee, if not set already. This will assign unallocated addresses to the xbees.
sorry, i am not very experienced and couldnt help much but i would like to see how u solved it.
WiFi modules do not have MY addresses.
