I recently got an error when I tried uploading my code on my Arduino Uno board. I also tried fixing it but still nothing works...
Here is my error info:
<Sketch uses 15904 bytes (49%) of program storage space. Maximum is 32256 bytes.
Global variables use 1754 bytes (85%) of dynamic memory, leaving 294 bytes for local variables. Maximum is 2048 bytes.
"C:\Users\NightFury\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\NightFury\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-PCOM3" -b115200 -D "-Uflash:w:C:\Users\NightFury\AppData\Local\Temp\arduino\sketches\4EA3E0E83E3A72D3F57D58F6CA07C715/Blink.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\NightFury\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x41
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x41
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1>
