I have two sketches and I want to combine them in one sketch
hi all,
I have two choices and I want to combine them in one sketch.I did it myself, but there was a name conflict.
thank you in advance for your help.
sketch 1
String ph1="0011"; //Enter your phone number to call #01
String ph2="22
33"; //Enter your phone number to call #02
int inputPin = 8;
int val=0;
bool flag=false;
Serial.print("AT+CMGF=1\r\n"); //Text SMS mode in GSM
pinMode(inputPin, INPUT);
digitalWrite(inputPin,LOW);
//System Calibration
for(int i=0;i<10;i++)
void loop(){
val = digitalRead(inputPin);
if (val == HIGH) {
flag=true;
else if(val==LOW) {
digitalWrite(inputPin,HIGH);
if (flag) {
message1(); //Generate the Alert Message First Mobile
message2(); //Generate the Alert Message Second Mobile
delay(60000); //1 minute delay
call1(); //Call to First mobile
call2(); //call to Second mobile
flag=false;
void message1() //Method to send message #01
Serial.print("AT+CMGS="");
Serial.print(ph1);
Serial.print(""\r\n");
delay(2000);
Serial.print("---ALERT---\n Human Trace Detected");
Serial.write(0x1A);
void message2() //Method to send message #02
Serial.print(ph2);
delay(2000);
Serial.write(0x1A);
void call1() //Method to get call #01
Serial.print("ATD");
Serial.print(ph1);
Serial.print(";\r\n");
delay(15000);
Serial.println("ATH");
void call2() //Method to get call #02
Serial.print(ph2);
delay(15000);
sketch 2
String ph2="22
int vibrationPin = 2;
bool flag=false;
pinMode(vibrationPin,INPUT);
digitalWrite(vibrationPin,LOW);
delay(200);
void loop(){
int a=vibration();
if(a>15000){
flag=true;
if (flag) {
flag=false;
Serial.print(ph1);
delay(2000);
Serial.print("---ALERT---\n Security Breach");
Serial.write(0x1A);
Serial.print(ph2);
delay(2000);
Serial.write(0x1A);
Serial.print(ph1);
delay(15000);
Serial.print(ph2);
delay(15000);
int vibration(){
delay(10);
int vibrationDetection=pulseIn(vibrationPin,HIGH); //wait for the pin to get HIGH and returns measurement
return vibrationDetection;
Please post what you tied and use code tags when you do
See Read this before posting a programming question
Those two sketches are basically the same sketch. Why do you need to combine them?
