I just bought an arduino nano avrdude: stk500_getsync(): not in sync: resp=0x00
I just bought a arduino nano atmega328. The Led keep on flashing and it does not upload the blink code. It says avrdude: stk500_getsync(): not in sync: resp=0x00
When I connect for the first time I maybe did not let the driver install properly by putting a code and removing the usb quickly. When I upload the rx blink a bit but the tx does not.
Any solution?
tahmod:
Does that mean that you disconnected the USB while an Upload was in progress?
try to rollabck your ftdi driver to an older version and try again
I removed by mistake, I thought it was completed.
How do you rollabck your ftdi driver to an older version?
My own problem.
I found this link after searching for solutions:
this can be a solution?
Sorry for my english, is no perfect.
tahmod:
Regardless.
At this point, I think that you need to *re-*bootload the microcontroller.
You need another Arduino for that or a USBtinyISP (or similar) to do that.
[If I'm wrong about this, I'm pretty sure that somebody will be along to bust me up for it.]
Hello all,
I confirm that my problem comunication Arduino Nano-> Pc ( S.O. windows Vista)
with error avrdude: stk500_getsync(): not in sync: resp=0x00
is solved with this solution showed in link below:
I found this link after searching for solutions.
I hope it can help anyone with the same problem.
tanks
edd1 your website is spanish. I dont understand. When I hold the shift button it give me this avrdude: usbdev_open(): did not find any USB device "usb"
