I just got an Arduino R4 wifi and i got an error
so i wanted to test the led matrix and after that every code that I enter is giving me this error
Cannot perform port reset: TOUCH: error during reset: opening port at 1200bps: Invalid serial port
No device found on COM5
Failed uploading: uploading error: exit status 1
Is your board connected to another com port?
no. Also the led matrix is still working
Perhaps it's worthwhile following the information gathering steps in the link below and seeing what light it sheds on the problem.
it just went away right now. But i have a question, how to stop the board to run the code?
I'm afraid that I have no idea what "how to stop the board to run the code" means.
Unplug it from all power sources, or modify the code to add a shutoff switch.
I'm not familiar with board.
  1. Keep the reset pressed.
  2. If the board has native USB, double tap the reset button; this should start the boot loader (for approximately 8 seconds) during which the board does not run your code.
