I just installed arduino 2.1.0 in windows 11 and when you open it it stays in the start window and does not finish starting
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.1.0
Starting backend process. PID: 10248
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/vdiadmin/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-14T18:06:36.556Z root INFO Backend Object.initialize: 19.3 ms [Finished 5.896 s after backend start]
2023-07-14T18:06:36.556Z root INFO Backend Object.configure: 16.1 ms [Finished 5.896 s after backend start]
2023-07-14T18:06:36.557Z root INFO Backend MessagingContribution.onStart: 7.4 ms [Finished 5.896 s after backend start]
2023-07-14T18:06:36.558Z root INFO Backend OSBackendApplicationContribution.configure: 0.9 ms [Finished 6.024 s after backend start]
2023-07-14T18:06:36.560Z root INFO Backend DefaultWorkspaceServer.onStart: 0.7 ms [Finished 6.024 s after backend start]
2023-07-14T18:06:36.561Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.3 ms [Finished 6.025 s after backend start]
2023-07-14T18:06:36.563Z root WARN Backend PluginLocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 126.7 ms [Finished 6.025 s after backend start]
2023-07-14T18:06:36.563Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.5 ms [Finished 6.025 s after backend start]
2023-07-14T18:06:36.565Z root INFO Backend ElectronTokenBackendContribution.configure: 1.9 ms [Finished 6.027 s after backend start]
2023-07-14T18:06:36.566Z config INFO >>> Initializing CLI configuration...
2023-07-14T18:06:36.567Z root INFO Backend PluginDeployerContribution.initialize: 1.0 ms [Finished 6.028 s after backend start]
2023-07-14T18:06:36.568Z root INFO Backend ConfigServiceImpl.onStart: 1.8 ms [Finished 6.029 s after backend start]
2023-07-14T18:06:36.578Z config INFO Loading CLI configuration from c:\Users\vdiadmin\.arduinoIDE\arduino-cli.yaml...
2023-07-14T18:06:36.580Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.8 ms [Finished 6.031 s after backend start]
2023-07-14T18:06:36.581Z root INFO Backend ArduinoDaemonImpl.onStart: 1.8 ms [Finished 6.033 s after backend start]
2023-07-14T18:06:36.581Z root INFO Backend NodeFileUploadService.configure: 3.8 ms [Finished 6.033 s after backend start]
2023-07-14T18:06:36.582Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-14T18:06:36.582Z discovery-log INFO start
2023-07-14T18:06:36.583Z discovery-log INFO start new deferred
2023-07-14T18:06:36.583Z root INFO Backend HostedPluginLocalizationService.initialize: 0.8 ms [Finished 6.035 s after backend start]
2023-07-14T18:06:36.584Z root INFO Backend BoardDiscovery.onStart: 2.2 ms [Finished 6.037 s after backend start]
2023-07-14T18:06:36.584Z root INFO Backend FileDownloadEndpoint.configure: 2.6 ms [Finished 6.038 s after backend start]
2023-07-14T18:06:36.585Z root INFO Backend AuthenticationServiceImpl.onStart: 2.2 ms [Finished 6.050 s after backend start]
2023-07-14T18:06:36.585Z root INFO Backend PluginApiContribution.configure: 2.1 ms [Finished 6.051 s after backend start]
2023-07-14T18:06:36.588Z root INFO Backend HostedPluginReader.configure: 1.5 ms [Finished 6.053 s after backend start]
2023-07-14T18:06:36.588Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 6.055 s after backend start]
2023-07-14T18:06:36.588Z root INFO Backend PlotterBackendContribution.configure: 2.1 ms [Finished 6.058 s after backendstart]
2023-07-14T18:06:36.598Z root INFO Theia app listening on http://localhost:64600.
2023-07-14T18:06:36.599Z root INFO Finished starting backend application: 16.0 ms [Finished 6.068 s after backend start]
2023-07-14T18:06:36.656Z root WARN The local plugin referenced by local-dir:/c%3A/Users/vdiadmin/.arduinoIDE/plugins does not exist.
2023-07-14T18:06:36.701Z root WARN The local plugin referenced by local-dir:/c%3A/Users/vdiadmin/.arduinoIDE/extensionsdoes not exist.
2023-07-14T18:06:36.807Z root WARN The local plugin referenced by local-dir:C:\Users\vdiadmin\.arduinoIDE\plugins does not exist.
2023-07-14T18:06:36.906Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.909Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-07-14T18:06:36.909Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.909Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-07-14T18:06:36.912Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.921Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-07-14T18:06:36.929Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.930Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-07-14T18:06:36.931Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.940Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-07-14T18:06:36.941Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.942Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-07-14T18:06:36.943Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.943Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-07-14T18:06:36.944Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.944Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-07-14T18:06:36.945Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.945Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-07-14T18:06:36.946Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.946Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-07-14T18:06:36.947Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.954Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-07-14T18:06:36.954Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.957Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-07-14T18:06:36.958Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.959Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-07-14T18:06:36.960Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.969Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-07-14T18:06:36.971Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.971Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-07-14T18:06:36.972Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-07-14T18:06:36.972Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.972Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-07-14T18:06:36.972Z root INFO PluginTheiaDirectoryHandler: accepting plugin with`Use code tags to format code for the forum` path
2023-07-14T18:06:36.973Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-07-14T18:06:36.973Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.973Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-07-14T18:06:36.974Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-14T18:06:36.974Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-07-14T18:06:36.974Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-07-14T18:06:36.985Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\vdiadmin\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-14T18:06:36.996Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-14T18:06:36.998Z config INFO Loaded the CLI configuration.
[9188:0714/120637.028:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
2023-07-14T18:06:37.036Z daemon INFO INFO[0000] Using config file: c:\Users\vdiadmin\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:64601
{"IP":"127.0.0.1","Port":"64601"}
2023-07-14T18:06:37.047Z daemon INFO Daemon is running.
2023-07-14T18:06:37.048Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/vdiadmin/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/vdiadmin/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-07-14T18:06:37.049Z config INFO Validating the CLI configuration...
2023-07-14T18:06:37.060Z config INFO The CLI config is valid.
2023-07-14T18:06:37.061Z config INFO <<< Initialized the CLI configuration.
2023-07-14T18:06:37.157Z root INFO Resolve plugins list: 587.0 ms [Finished 6.626 s after backend start]
2023-07-14T18:06:37.181Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 23.1 ms [Finished 6.650 s after backend start]
2023-07-14T18:06:37.225Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\ProgramFiles\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 45.0 ms [Finished 6.695 s after backend start]
2023-07-14T18:06:37.252Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 26.4 ms [Finished 6.721 s after backend start]
2023-07-14T18:06:37.274Z daemon INFO INFO[0000] Loading hardware from: C:\Users\vdiadmin\AppData\Local\Arduino15\packages
INFO[0000] Loading libraries index file index="C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15\\library_index.json"
INFO[0000] Adding libraries dir dir="C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15\\libraries"
location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\vdiadmin\\Documents\\Arduino\\libraries" location=user
2023-07-14T18:06:37.278Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2023-07-14T18:06:37.279Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2023-07-14T18:06:37.280Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2023-07-14T18:06:37.281Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\library_index.json:The system cannot find the file specified.
2023-07-14T18:06:37.287Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-07-14T18:06:37.288Z daemon INFO INFO[0000] Updating libraries index
2023-07-14T18:06:37.298Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 46.6 ms [Finished 6.768 s after backend start]
2023-07-14T18:06:37.300Z daemon INFO INFO[0000] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-07-14T18:06:37.302Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 3.5 ms [Finished 6.772 s after backend start]
2023-07-14T18:06:37.443Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 141.3 ms [Finished 6.913 s after backend start]
2023-07-14T18:06:37.444Z daemon INFO INFO[0000] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
INFO[0000] Starting download url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2023-07-14T18:06:37.447Z root INFO core-client-provider [platform-index]
2023-07-14T18:06:37.448Z root INFO core-client-provider [library-index]
2023-07-14T18:06:37.614Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 170.7 ms [Finished 7.084 s after backend start]
2023-07-14T18:06:37.829Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 214.2 ms [Finished 7.298 s after backend start]
2023-07-14T18:06:38.070Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 241.1 ms [Finished 7.539 s after backend start]
2023-07-14T18:06:38.248Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 178.1 ms [Finished 7.717 s after backend start]
2023-07-14T18:06:38.329Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 81.3 ms [Finished 7.799 s after backend start]
2023-07-14T18:06:38.521Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 190.6 ms [Finished 7.990 s after backend start]
2023-07-14T18:06:38.742Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 221.1 ms [Finished 8.211 s after backend start]
2023-07-14T18:06:38.960Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 218.1 ms [Finished 8.430 s after backend start]
2023-07-14T18:06:39.052Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 91.8 ms [Finished 8.522 s after backend start]
2023-07-14T18:06:39.218Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 165.7 ms [Finished 8.687 s after backend start]
2023-07-14T18:06:39.387Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 169.5 ms [Finished 8.857 s after backend start]
2023-07-14T18:06:39.564Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 176.6 ms [Finished 9.034 s after backend start]
2023-07-14T18:06:39.733Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 168.9 ms [Finished 9.203 s after backend start]
2023-07-14T18:06:39.840Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 107.0 ms [Finished 9.310 s after backend start]
2023-07-14T18:06:40.019Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 146.0 ms [Finished 9.456 s after backend start]
2023-07-14T18:06:40.022Z root INFO Deploy plugins list: 587.0 ms [Finished 9.489 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-07-14T18:06:41.746Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 648.0 ms [Finished 4.947 s after frontend start]
2023-07-14T18:06:47.249Z root ERROR Failed to update platform, library indexes.
2023-07-14T18:06:47.254Z daemon INFO INFO[0010] Loading hardware from: C:\Users\vdiadmin\AppData\Local\Arduino15\packages
2023-07-14T18:06:47.257Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
2023-07-14T18:06:47.259Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
2023-07-14T18:06:47.261Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
2023-07-14T18:06:47.263Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\library_index.json:The system cannot find the file specified.
2023-07-14T18:06:47.264Z daemon INFO INFO[0010] Loading libraries index file index="C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15\\library_index.json"
INFO[0010] Adding libraries dir dir="C:\\Users\\vdiadmin\\AppData\\Local\\Arduino15\\libraries"
location=ide
INFO[0010] Adding libraries dir dir="C:\\Users\\vdiadmin\\Documents\\Arduino\\libraries" location=user
2023-07-14T18:06:47.268Z root ERROR Uncaught Exception:
2023-07-14T18:06:47.268Z root ERROR Error: The index of the cores and libraries must be updated before initializing thecore gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
[platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
[library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\vdiadmin\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
at isIndexUpdateRequiredBeforeInit (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
at CoreClientProvider.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async ClientReadableStreamImpl.<anonymous> (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184:31)
[5096:0714/120830.779:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
type or paste code here
That's new. Never heard about it before. Are You sure the dowload/installation ran without any disturbance?
