I just want to display a string using GLCD!
I have been programming for 20 years using BASIC, Pascal, assembly and recently Java but I have never needed to use C until the last week when I got an Arduino.
I have built a device using a 1280 with 4 line LCD, PS2 and IR interfaces and a few other bits and have written a program with a menu system that works but I have now spent more time on one silly little problem than on everything else and it is driving me loopy!
GLCD.Puts(variable); does not work for strings only arrays of chars.....
I have been pointed towards using the RC2 of the latest library but cannot find where that is.
I have been trying to use toCharArray again with no luck
I have tried writing a function to do it but again with no luck....
This is a function I wrote:
void printstring(String toprint){
char outputstring[255];
int i = 0;
while (i <= toprint.length() -1) {
  if (i>255) {
    i = 255;
  outputstring[i] = toprint.charAt(i);
  i++;
 outputstring[i] = 0;
 GLCD.Puts(outputstring);
and I want to drive it with
  String test = 'xxxThis is a test';
  printstring(test);
I appreciate it is not very efficient etc but something that works would be better than something that is pretty!
When I run this code instead of displaying "xxxThis is a test" it displays "29556" !! I assume that this is the address of the string rather than it's value.
I have read the documentation but I still cannot fathom what * is in relation to char arrays either.
This is going to be one of those really newbie questions but I am really banging my head against the wall and it is holding up the whole project!
So? Extract the array of chars from the string, to print. Look at the String::toCharArray() function.
All of what documentation? You might take a look at a standard C book. Particularly the section(s) on pointers. You don't know C until you KNOW pointers.
Thanks PaulS,
I will learn C as I have learnt several dialects of BASIC, PASCAL and about 5 types of assembler (plus a starting knowledge of JAVA). It was on my to do list for quite a while. I am picking it up as we speak and have written a menu system for GLCD complete with input routine etc. This is just one thing that I am having trouble with and cannot work out!
I have a theoretical knowledge of the structures having used assembler and written such structures myself but was having problems with syntax etc....
