system
July 16, 2013, 2:44am
1
I've been using my Arduino Uno for a few months without any problems. Today I tried to compile a sketch and it gave me a Error compiling message. It didn't give me any errors in the output field. I tried it again with the Blink sketch and it gave me the same error.
If it's at all helpful, this is what the output said,
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build7313227511724971617.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build7313227511724971617.tmp\Blink.cpp.o
Any help would be greatly appreciated.
Under File:Preferences, check the verbose output boxes, recompile again and post all the notes that come up.
Perhaps your IDE got corrupted. You could try reloading it.
system
July 16, 2013, 4:05am
3
The verbose output boxes were checked, that was the entirety of the output. I uninstalled the IDE and reinstalled it, it gives me the same problem.
When I select Uno, and Blink sketch, I see all this when Verify button is clicked. You can enlarge the IDE window and the lower section, highlight all that is there:
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\malloc.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\realloc.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\realloc.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\WInterrupts.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\WInterrupts.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_analog.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_analog.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_digital.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_digital.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_pulse.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_pulse.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\wiring_shift.c -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\wiring_shift.c.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\CDC.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\CDC.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\HardwareSerial.cpp.o
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\HID.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\HID.cpp.o
C:\Arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Arduino-1.0.5\hardware\arduino\variants\standard C:\Arduino-1.0.5\hardware\arduino\cores\arduino\IPAddress.cpp -o C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\IPAddress.cpp.o
: AND SO ON, EDITED TO FIT IN ONE POST
C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.elf C:\Users\Owner\AppData\Local\Temp\build9091158565282831635.tmp\Blink.cpp.hex
Binary sketch size: 1,084 bytes (of a 32,256 byte maximum)
system
July 16, 2013, 4:17am
5
C:\Program Files (x86)\Arduino\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build995371091343257421.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build995371091343257421.tmp\Blink.cpp.o
That's everything.
Wow, that doesn't look right at all.
I don't know what to advise when it just stops like that.
Any chance its a Windows permission issue, not letting the IDE create needed folders or something like that?
system
July 16, 2013, 4:45am
8
I just tried running as administrator, I got the same error but it gave me a lot more information.
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Blink.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Blink.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\malloc.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\malloc.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\avr-libc\realloc.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\realloc.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WInterrupts.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WInterrupts.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_analog.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_analog.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_digital.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_digital.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_pulse.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_pulse.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-gcc -c -g -Os -Wall -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\wiring_shift.c -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\wiring_shift.c.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\CDC.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\CDC.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\HardwareSerial.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
system
July 16, 2013, 4:46am
9
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\HID.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\HID.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\IPAddress.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\IPAddress.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\main.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\main.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\new.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\new.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Print.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Print.cpp:44: warning: 'progmem ' attribute ignored
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Stream.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Stream.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Tone.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\Tone.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\USBCore.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\USBCore.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WMath.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WMath.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=105 -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino -IC:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\variants\standard C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\arduino\cores\arduino\WString.cpp -o C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\WString.cpp.o
C:\Users\PhyberLogik\Desktop\arduino-1.0.5\hardware\tools\avr\bin\avr-ar rcs C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\core.a C:\Users\PHYBER~1\AppData\Local\Temp\build823348354024237642.tmp\malloc.c.o
Ok, we need some software guru help here. I don't all that should be coming up.
If you compile a 2nd time, does it do the same?
system
July 16, 2013, 5:14am
11
It does the same thing every time.
Okay, I'm calling in the cavalry - sent a request to the other moderators. Some one is bound to have seen this.
What is your computer & operating system? Does it have any recent upgrades/patches?
system
July 16, 2013, 6:14am
14
I'm running Windows 8. 1.30 GHz processor, 2GB Ram. It's a Toshiba Satellite C855D-S5302. No upgrades of any kind. I'm using 38GB out of 287GB on my C drive.
leo72
July 29, 2013, 9:24am
15
I don't use Windows but are you using the right IDE for the right OS?
I mean, are you using a 32-bits IDE on a 64-bits OS? Have you downloaded the IDE installer or the IDE package?
I see "programs-(x86)" into your path.
Try completely removing the IDE and downloading again the installer.
system
July 29, 2013, 11:56am
16
Windows 8 x64 is perfectly capable of running 32bit programs. Phyberlogik has already reainstalled the IDE. His (and my) problem persists, even when using the .exe installer.
system
August 6, 2013, 10:54pm
17
I've found that if you're using Windows 8, refreshing your system seems to fix the problem. I know it's like going after housefly with a bazooka but it seems to do the trick.
