I replaced the value with 125. still same problem.
So, try a much smaller value, at least temporarily. If you set it to 25, and things work, increase from there. If not, you may have a hardware problem, or the problem is elsewhere in your code.
same problem with 25. Im pretty sure its a coding problem. I keep getting "Temp Trigger 1" flash o nthe screen so im gonna assume theres an error in this part of the code.
/** LCD Shield */
serLCD lcd(13); // use both lines
char buf[5]; //used in conversion of int to char for lcd
int configure = 0; //use select as an on/off for configuring
int showReading = 0; //select which value to modify 0-3
int adc_key_in = 1024; //Start with -1 key value
int adc_key_val[5] = {
100, 160, 360, 770, 800 }; //Analog values from Keys on keypad shield
65, 218, 393, 601,1000};
int NUM_KEYS = 5;
int key= -1;
char trigger_names[4][15] = {
"Temp Trigger 1",
"Temp Trigger 2",
"Humid Trigger",
"C02 Trigger" };
/* Set up index value for storing values in eeprom*/
int k=0;
The only thing in that part of the code that jumps out is the useless comments.
Post (again) all of your code. As an attachment (click Additional Options... - it is selectable), if it won't fit all in one post.
thats the code with all my edits. the original code can be found here:
or more specifically:
http://www.instructables.com/files/orig/FMK/3BR4/GAPURHM2/FMK3BR4GAPURHM2.tmp
Mushroom.ino (16.1 KB)
