i am using arduino droid to do this. after i fixed the other error i got this one " undifined reference to 'setup'/ loop' ". if you find the problem please tell me. or if i should use something different.
// code to control continuous rotation servo with potentiometer
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int pot; // variable for potentiometer analog reading, 0-123
int speed; // variable for servo speed, 0-180.
// servo is STOPPED at speed = 90
// full speed in either direction at 0 or 180.
// this is NOT the servo's angular position
// setup code that only runs once
myservo.attach(8); // use pin 8 to control the servo
// code that loops repeatedly
pot = analogRead(A0); // read analog voltage from potentiometer
speed = map(pot, 0, 1023, 0, 180); // convert analog reading 0-1023 to speed 0-180
myservo.write(speed); // send control signal to servo
put your main code here, to run repeatedly:
