I keep getting this error | error: expected unqualified-id before '{' token
i keep getting the error, 29:1: expected unqualified-id before '{' token, but I have tried everything I can think of that I could do to fix it
int cm = 0;
long readUltrasonicDistance(int triggerPin, int echoPin)
  pinMode(triggerPin, OUTPUT);
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  pinMode(echoPin, INPUT);
  return pulseIn(echoPin, HIGH);
void neutral()
  digitalWrite(4, LOW);
  digitalWrite(3, LOW);
  digitalWrite(2, LOW);
  digitalWrite(5, LOW);
  digitalWrite(6, LOW);
  digitalWrite(7, LOW);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(10, LOW);
  digitalWrite(13, LOW);
void stop()
  digitalWrite(3, HIGH);
  digitalWrite(2, HIGH);
  digitalWrite(5, HIGH);
  digitalWrite(7, HIGH);
  digitalWrite(10, HIGH);
  delay(250);
void forward()
  digitalWrite(4, HIGH);
  digitalWrite(6, HIGH);
void backward()
  digitalWrite(8, HIGH);
void turnleft()
  digitalWrite(9, HIGH);
void turnright()
  digitalWrite(13, HIGH);
void ultrasetup()
  //has errors, fix!!
  int cm = 0;
  cm = 0.01723 * readUltrasonicDistance(12, 11);
  Serial.print(cm);
  Serial.println("cm");
  delay(100);
  //for motors
  pinMode(4, OUTPUT); //input 1
  pinMode(3, OUTPUT); //enable 1 & 2
  pinMode(2, OUTPUT); //input 2
  pinMode(7, OUTPUT); //input 4
  pinMode(6, OUTPUT); //input 3
  pinMode(5, OUTPUT); //enable 3 & 4
  //for Led's\\
  pinMode(8, OUTPUT); //reverse lights
  pinMode(10, OUTPUT); //Braking lights
  pinMode(9, OUTPUT); //blikers
  pinMode(13, OUTPUT); //blikers
  Serial.begin(9600); //for ultrasonic sensor
  //------for ultrasonic sensor------\\
  ultrasetup();
  turnleft();
[color=#ff5f48]​any help would be appreciated,[/color]
[color=#ff5f48]thanks[/color]
Delete this line or the \ on the end
The \ on the end is seen as an editor line continuation character by the IDE
Did you mean
