I keep getting these errors:
/Users/TaylorRichard/Documents/Arduino/SimpleWebServerWiFi/SimpleWebServerWiFi.ino: In function ‘void loop()’:
SimpleWebServerWiFi:101: error: a function-definition is not allowed here before ‘{’ token
SimpleWebServerWiFi:119: error: expected ‘}’ at end of input
exit status 1
And I have no clue on how to fix this problem
CODE:
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "STMARY_MCHS"; // your network SSID (name)
char pass[] = "stmaryschools"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
#define RELAY1 7
#define RELAY2 6
#define RELAY3 5
#define RELAY4 3
Serial.begin(9600); // initialize serial communication
pinMode(RELAY1, OUTPUT); // set the RELAY mode
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
String fv = WiFi.firmwareVersion();
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
void printWifiStatus(); // you're connected now, so print out the status
static int relayVal = 0;
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Click <a href=/?on7 >7 ON</a> turn the Light on RELAY1 on
client.print("Click <a href=\?off7 >7 OFF</a> turn the Light on RELAY1 off
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else {
relayVal ^= 1; // xor current value with 1 (causes value to toggle)
if (relayVal)
Serial.println("Relay on");
Serial.println("Relay off");
if (relayVal)
digitalWrite(RELAY1, HIGH);
digitalWrite(RELAY1, LOW);
// close the connection:
client.stop();
Serial.println("client disonnected");
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
I am a beginner.
