I keep on getting an error.. HELP!
#include <Servo.h>
Servo myservo1; // create servo object to control a servo
// twelve servo objects can be created on most boards
Servo myservo2; // create servo object to control a servo
Servo myservo3; // create servo object to control a servo
int pos = 0; // variable to store the servo position
myservo1.attach(9); // attaches the servo on pin 9 to the servo object
myservo2.attach(8); // attaches the servo on pin 8 to the servo object
myservo3.attach(7); // attaches the servo on pin 7 to the servo object
int randNumber = random(1, 3);
Serial.println(randNumber);
int del = random(1000, 16,000);
delay (del);
if randNumber = myservo1
// in steps of 1 degree
myservo1.write(90);
myservo2.write(90);
myservo3.write(90);
delay(2000);
myservo1.write(pos); // tell servo to go to position in variable ‘pos’
myservo2.write(pos);
myservo3.write(pos);
// waits 15ms for the servo to reach the position
this is not defined "myservo "
delay(2000);
myservo.write(0); // tell servo to go to position in variable 'pos'
i think you need to do this
delay(2000);
this is working for me
a55830:
delay(2000);
delay(2000);
Thanks man.. Now it is telling me
'exit status 1
no matching function for call to 'random(int, int, int)'
I HAVE RE-MODIFIED MY CODE SO PLEASE COPY AND PASTE TO SEE WHAT THE PROBLEM IS.. IF YOU CAN
your if command looks wrong
look here : https://www.arduino.cc/en/Reference/If
#include <Servo.h>
  int  del = random(1000,16000);
  delay (del);
    if (randNumber == 1){
    myservo1.write(90);
  if (randNumber == 2){
    myservo2.write(90);
 if (randNumber == 3){
    myservo3.write(90);
  delay(2000);
      myservo1.write(pos);              // tell servo to go to position in variable 'pos'
a55830:
#include <Servo.h>
  delay (del);
    myservo1.write(90);
    myservo2.write(90);
    myservo3.write(90);
  delay(2000);
I am basically trying to turn the servo that randomly gets chosen. For example if it is 1… myservo1 moves… if its 3 than myservo3 moves… How can I improve my if command so it does that?
Thank you
look at the code i posted
a55830:
Sorry!.. i didnt realize that you made changes. Thank you.
Please use the code tags button </> when you post code
Benny_Leonard:
Thanks man… Now it is telling me
'exit status 1
no matching function for call to ‘random(int, int, int)’
When you get that error you’ll notice that a line is highlighted in pink, that indicates there’s a problem on or near that line:
So rather than running straight to the forum, take some time to look at your code. If you look closely at that you’ll see you are trying to pass 3 arguments to random(): 1000, 16, and 000. I think what you wanted to do was random(1000, 16000). Always use Tools > Auto Format on your code, that will help bugs such as this to be more clear.
i think i got it working now with 3
look at code copy all of it , servos have been moved to pin 11 , 10 , 9 all pins power managed
#include <Servo.h>
int pos = 10;    // variable to store the servo position
  myservo2.attach(10);  // attaches the servo on pin 8 to the servo object
  myservo3.attach(11);  // attaches the servo on pin 7 to the servo object
  Serial.print("Servo : ");
  int  randPos = random(10, 150);
  Serial.print("Random Pos : ");
  Serial.println(randPos);
  int  del = random(1000, 2000);
  Serial.print("delay : ");
  Serial.println(del);
  delay (del);
  if (randNumber == 1) {
    myservo1.write(randPos);
    Serial.println("moving1");
  else if (randNumber == 2) {
    myservo2.write(randPos);
    Serial.println("moving2");
  else {
    myservo3.write(randPos);
    Serial.println("moving3");
  delay(1500);
