So I am trying to create a arduino project that uses a buzzer, keypad and ultrasonic sensor to detect packages and also to incorporate a mini "alarm" along with it if the packages are taken without inputting a code. No matter how many times I try to compile it:
CONSTANTS//
ULTRASONIC SENSOR
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long a;
#pragma GCC disagnostic ignored ""-Wwrite-strings"
// Defining where the Ultrasonic sensor is connected//
ACTIVE BUZZER
int buzzer = 12;//the pin of the active buzzer
int duration, distance;//Initializing the buzzer
KEYPAD
#include <Keypad.h>char* password = "185"; //This is the security code which can be changed
char* temppassword = "";
int position = 0;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keypressed;
//define the cymbols on the buttons of the keypads
char keyMap[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad//initialize an instance of class NewKeypad
Keypad myKeypad = Keypad( makeKeymap(keyMap), rowPins, colPins, ROWS, COLS);// The last step was to intialize the keypad
pinMode(TRIG_PIN,OUTPUT);//intitialize the trig pin as an output
pinMode(ECHO_PIN,INPUT);//intiialize the echo pin as an input
pinMode(buzzer,OUTPUT);//initialize the buzzer pin as an output}
long duration, distance;
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
duration = pulseIn(ECHO_PIN, HIGH);
distance = (duration/2) / 29.1;if (distance <= 30) {
Serial.println("Object Detected.");
digitalWrite(buzzer, LOW);
if (distance >30) {
Serial.println("Object has left proximity, Return Object or Enter Security Code");
keypressed = myKeypad.getKey();
if(keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
keypressed == '4' || keypressed == '5' || keypressed == '6' || keypressed == '7' ||
keypressed == '8' || keypressed == '9')
if (keypressed != NO_KEY)
if (keypressed == '0' || keypressed == '1' || keypressed == '2' || keypressed == '3' ||
temppassword +- keypressed;
if(keypressed == '*')
if (temppassword == password )
Serial.println("You may take your package.");
digitalWrite (buzzer, LOW);
} else
Serial.println("Authorities have been contacted.");
tone(buzzer, 400); // play 400 Hz tone for 500 ms
tone(buzzer, 800); // play 800Hz tone for 500ms
noTone(buzzer);
if (keypressed == '#')
{temppassword="";
digitalWrite(buzzer,LOW);
I keep on receiving these error messages:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Compiling libraries...
Compiling library "HC-SR04"
Using previously compiled file: C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\HC-SR04\SR04.cpp.o
Compiling library "Keypad"
Using previously compiled file: C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\Keypad\Keypad.cpp.o
Using previously compiled file: C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\Keypad\utility\Key.cpp.o
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037/Package_Protector.ino.elf" "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\sketch\Package_Protector.ino.cpp.o" "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\HC-SR04\SR04.cpp.o" "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\Keypad\Keypad.cpp.o" "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037\libraries\Keypad\utility\Key.cpp.o" "C:\Users\Andre\AppData\Local\Temp\arduino_build_311037/..\arduino_cache_943630\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Andre\AppData\Local\Temp\arduino_build_311037" -lm
C:\Users\Andre\AppData\Local\Temp\cc2gVHZI.ltrans0.ltrans.o: In function `Keypad::pin_read(unsigned char)':C:\Users\Andre\OneDrive\Documents\Arduino\libraries\Keypad/Keypad.h:89: undefined reference to `digitalRead'
C:\Users\Andre\AppData\Local\Temp\cc2gVHZI.ltrans0.ltrans.o: In function `Keypad::pin_write(unsigned char, bool)':
C:\Users\Andre\OneDrive\Documents\Arduino\libraries\Keypad/Keypad.h:88: undefined reference to `digitalWrite'
C:\Users\Andre\AppData\Local\Temp\cc2gVHZI.ltrans0.ltrans.o: In function `Keypad::pin_mode(unsigned char, unsigned char)':
C:\Users\Andre\OneDrive\Documents\Arduino\libraries\Keypad/Keypad.h:87: undefined reference to `pinMode'
C:\Users\Andre\AppData\Local\Temp\cc2gVHZI.ltrans0.ltrans.o: In function `_GLOBAL__sub_I_sr04':
C:\Users\Andre\OneDrive\Documents\Arduino\libraries\HC-SR04/SR04.cpp:7: undefined reference to `pinMode'
C:\Users\Andre\OneDrive\Documents\Arduino\libraries\HC-SR04/SR04.cpp:8: undefined reference to `pinMode'
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
Using library HC-SR04 in folder: C:\Users\Andre\OneDrive\Documents\Arduino\libraries\HC-SR04 (legacy)
Using library Keypad in folder: C:\Users\Andre\OneDrive\Documents\Arduino\libraries\Keypad (legacy)
exit status 1
Error compiling for board Arduino/Genuino Uno.
What can I do to fix it?
