I know little about programming, and have a specific question.
My code is receiving an error, and I am using a tutorial. The tutorial is located at this webpage: http://blog.tinyenormous.com/2009/09/30/17-arduino-nikon-ir-intervalometer-code/
The code that I need help with is as follows:
void snap(){
    int i;
    digitalWrite(PIN_STATUS,  1);
          for(i=0;i”);
          sequence[i] = (sequence[i] * FREQ) / (intervalle * 1000);
          Serial.println(sequence[i]);
The error:
stray '/' in program
    for(i=0;i”);
source of your error
Thank you, now how can I fix it? I am not familiar with this syntax, however, I know lua, and sometimes it gets confusing.
I thought you're going off a tutorial. Here's instructions on for loop http://arduino.cc/en/Reference/For
I am, but the tutorial code is incorrect, so could you help me fix this one line of code?
Here is exactly how to do it:
for(i=0; i<100; i++){
The i<100 means it would repeat 100 times. Which is repeat until i is no longer smaller than 100. i++ means add one every time the for() function runs.
Read more about the for function:
Thank you, but now I get the error intervalle was not declared in this scope.
If needed, here is the full code:
// ----- C -------
 * arduino Nikon IR remote
 * @license	Creative commons: Attribution-Noncommercial-Share Alike 3.0 (http://creativecommons.org/licenses/by-nc-sa/3.0/)
 * @author Aurelien ANTOINE
 * version 1
 * date 20081217
 * found by ross here http://ilpleut.be/doku.php/code:nikonremote:start
#define PIN_STATUS 13
#define PIN_IR_LED 12
#define FREQ 38400  // IR frequence
int hyst=20;
int PotVal = 0;
int count = 0;
int oldVal=0;
//shutter sequence (on,off,on,off ... in microsecond)
unsigned long sequence[] = {2000,27830,390,1580,410,3580,400,63200,2000,27830,390,1580,410,3580,400,0};
int seq_l;
//oscd is a delay in microsecond used at each oscillation.
int oscd;
void oscillate(int pin, unsigned long n, int shine){
	int ir_status=0;
	while(n>0){
		n--;
		delayMicroseconds(oscd);
		ir_status  =  !ir_status;
		digitalWrite(pin,  ir_status && shine);
void snap(){
	int i;
	int min=1, max=100, i;
	int last_oscd=0;
	unsigned long before, intervalle;
	oscd=max;
	seq_l = sizeof(sequence)/sizeof(unsigned long);
	pinMode(PIN_STATUS, OUTPUT);
	pinMode(PIN_IR_LED, OUTPUT);
	Serial.begin(28800);
	//this "while" will process the best "oscd"
	Serial.println("Ready");
	while(last_oscd!=oscd){
		last_oscd=oscd;
		oscd=(min+max)>>1;
		before=millis();
		oscillate(PIN_STATUS, FREQ, 1);
		intervalle=millis()-before;
		if(intervalle >= 1000) max=oscd;
		else min=oscd;
		Serial.print(intervalle);
		Serial.print(" : ");
		Serial.print(min);
		Serial.print("<->");
		Serial.println(max);
	Serial.print("oscd: ");
	Serial.println(oscd);
	//rewrite the sequence array, we replace all values in microsecond by the number of oscillation
	for(i=0;i<seq_l;i++){
		Serial.print(sequence[i]);
		Serial.print("->");
	//make a photo, wait 10 seconds
PotVal=0;
  for (count = 0; count < 10; count++) { //loops 10 times
    PotVal = (PotVal + analogRead(1))/100; //adds the pot readings together
  //PotVal = (PotVal / 100); // finds average of readings
  Serial.print("Interval is ");
    Serial.print(PotVal);
    Serial.println(" seconds.");
	snap();
delay(PotVal*1000);
intervelle is declare in loop(), but you are trying to use it in snap(). It should be made global.
Like I said, I have no coding experience besides lua, and so I will need help making this global. What do I need to change?
Beatz1337: Like I said, I have no coding experience besides lua
But you have Google, don't you?
Try googling C++ global scope to see some simple examples.
Ok, and if it gets moved to become a global variable, will it still be able to change as the pot changes?
Beatz1337: will it still be able to change as the pot changes?
It doesn't do that now.
