I know this can be done with less code!!
I'm making a midi sequencer with the seeedstudio TFT shield.
I made a little gird for the sequencer and need the squares to toggle between black and blue to show if it's active or not. I have a way to place the square in the correct spot but I can't figure out how to do it efficiently. I need to be able to toggle them at any time...
Heres the chunch of code that plots the square.
I'll put the whole thing in the attachment.
I assume I would have to iterate over it somehow and change the the values in the if statements but I'm still kindof a noob and I'm not entirely sure what I'm doing.
Thanks for the help!
//GRID TOGGLES
if (x > 0 && x < 60 && y > 180 && y < 240) //first square
//have to have way to tell if it's already selected or not
if (seqBool[0]==0)
//fill square
Tft.fillRectangle(1, 181, 59,59,CYAN); //slightly smaller square fits inside blue grid square. hense 61 instead of 60
seqBool[0]=1;
Tft.fillRectangle(1, 181, 59,59,BLACK); //slightly smaller square fits inside blue grid square. hense 61 instead of 60
seqBool[0]=0;
tftSequencer.ino (10.7 KB)
Yes. A for loop would be good. Actually a pair of them for handling the rows and the columns.
Yes, based on the loop indices.
Try something. If it doesn't work, and you can't figure out why, we'll be here all week.
I ran into the same 'slow' fillRectangle problem with the 3.2 TFT display.. fillRectangle is a slow function..
drawRectangle is fast if u can use that instead..
U might check the TFT.h and see if theres any notes on speeding up fill functions
I see nothing in 'TFTv2.h' that suggests a way to speed it up, but as PaulS say's looping the drawing of like sized rectangles can be simplified and made easier to read.
    int16_t     _left;
    int16_t     _top;
    int16_t     _width;
    int16_t     _height;
    rect_t(int16_t left = 0, int16_t top = 0, int16_t width = 0, int16_t height = 0)
        : _left(left), _top(top)
        , _width(width), _height(height)
    rect_t& operator= (const rect_t& rhs)
        _left   = rhs._left;
        _top    = rhs._top;
        _width  = rhs._width;
        _height = rhs._height;
        return *this;
    rect_t& offset(int16_t dx, int16_t dy)
        _width   += dx;
        _height  += dy;
        return *this;
    int16_t left() const    { return _left; }
    int16_t top() const     { return  _top; }
    int16_t width() const   { return _width; }
    int16_t height() const  { return _height; }
void drawGrid()
    // ... allocate an instance of rect_t named 'rect' ...
    // ... 'rect' will be initialized a to 0, 0 and a width and height of 12, 60 ...
    rect_t  rect(0, 0, 12, 60);
    for ( size_t iCol = 0; iCol < 3; iCol++ )
        // ... allocate another instance of 'rect_t' named 'rc' and initialize it with the existing rectangle 'rect' ...
        rect_t  rc = rect;
        // ... offset instance 'rc' by 'iCol' times its width ...
        rc.offset(iCol * rc.left(), 0);
        Tft.drawRectangle(rc.left(), rc.top(), rc.width(), rc.height(), BLUE);
this likely wont work for u, but u might find similar--
http://forum.arduino.cc/index.php?topic=140111.30
i should have included this link--
theres some good ideas there
I've recently been using the Adafruit GFX and MCUFRIEND_kbv libraries and find them extremely fast on the UNO. For reasons I don't fully understand, the routines seem about half as fast on a Mega board.
BTW, I have this 3.95" TFT color display
http://www.ebay.com/itm/322009754655?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
working on the UNO with the libraries above and it is very nice. However, I am running out of Flash, hence the try with the Mega, but the graphics are not as fast as I'd like. I'd really like to get the code moved to a Teensy 3.2, but have not been able to get the libraries to compile with it. If there are any Teensy experts out there who have a good graphics engine, I'd love to hear about it.
I'm having trouble trying to figure this out with for loops.
It works fine if I type it ALL out but that takes forever and is hard to read.
ZachhacZ:
Reply #3
lloyddean:
Reply #3
Sorry I failed to notice that...
It's a little over my head could you explain whats going on?
