I’m a Arduino newbie
Hi… I just purchased some Arduino hardware and am attempting to make this happen: is this programming possible ?
  1. Rotate a FEETECH brand 35KG Servo Motor 360 Degree High Torque Digital Servo..
  2. Need the servo to rotate a full circle, stop and back to starting position
  3. Need this process to be slow ..1 minute will work..
  4. Need this to happen every 15 minutes from 7pm to 7am
  5. The servo has a 3 volt laser mounted on it and needs to be on only when the servo motor is running
  6. I am using a Arduino uno board
Welcome to the forum
What you list is quite possible to do with a Uno but note the following :
  • the servo must not be powered directly from the Uno 5V pin. An external power supply is required
  • the servo must be able to have its position controlled rather than its speed and direction. I am suspicious from your description as to whether that is possible with the servo that you have. Please post a link to the servo so that we can see its specification
Ok thank you so much for your reply.. I do have a separate power supply.. here are the servos specs..
  • HIGH ROTATION SPEED SERVO: A high-torque servo, the rotation angle is 360 degrees (at 500→2500μsec), when the power is stopped, it can rotate 360 degrees. Dead width ≤ 4 μsec. Durable and reliable.
  • STRONG STALL TORGUE MOTOR: The operating voltage range is 4V-8.4V, the stall torgue is (6V) 400.65oz/in(28.8kg/cm), (7.4V) 493.86oz/in(35.5kg/cm). The servo size is 55X20X43mm.
Model: FT6335M
Product Name: 7.4V 35kg.cm digital 360 degree magnetically coded aluminum mid-shell servo
Storage Temperature Range -30℃~80℃
Operating Temperature Range: -20℃~60℃
Size: A:55mm B:20mm C:43mm
Weight: 67土1g
Gear type: Steel tooth
Limit angle: NO limit
Bearing: Ball bearings
Horn gear spline: 25T/5.9mm
Horn type: Plastic,POM
Case: PA+A lumi num
Connector wire: 30CM
Motor: Core Motor
Operating Voltage Range: 6V-7.4V
Idle current (at stopped) . 6MA@7.4V
No load speed: 0.192sec/60°@7.4V
Runnig current(at no load) : 180mA@7.4V
Peak stall torque: 35.5kg.cm@7.4V
Rated torque: 11.8kg.cm@7.4V
Stall current: 3.9mA@7.4V
Command si gnal Pulse width modification
Amplifier type Digitalcompara tor
Pulse width range 500~2500usec
Stop position 1500μ sec
Running degree 360° .at500- > 2500 μ sec)
Dead band width ≤4.μ sec
Rotating direction Counterclockwise (在1 500→2000μ sec)
I’m willing to pay $$ to get this project completed !!
Do you want the topic moved to the appropriate forum category ?
Sure
If this will be a request for paid assistance, it would be better to change the topic title to something more informative about your project
The topic has been moved. Please change the title to something more meaningful
Sounds like you're making a sign for a business.
No.. I’m not.. I’m making a automated laser to keep geese off of my daughters quarry…
Please heed the advice to change the title of the topic otherwise it will not attract the attention of someone who can do the job
Please heed any rules and regulations about laser operation on a worksite or public place.
What is the laser supposed do to the "keep" the geese away?
Tom.. :smiley: :+1: :coffee: :australia:
Turns them into Phoenixes.
:astonished:
