I´m a beginer
Hi All
is my first serius proyect with Arduino.
I would like to have with rfid card (rc522).
Im really lost with it.
first i need is to insert a new code in the cards (which commands it works with?, each card gonna be a trigger command to order ,later ,when we read it.
Then reading:
the plan is to have 3 different cards (3 diferents numbers)
if card is number one i have to send an udp command with "play1"
if card is number two i have to send an udp command with "play2"
same with three...
the destination port will be 198.162.0.211
port 5000.
May anyone helps me?
google
arduino rfid card library
arduino rfid card project
and select an example from the many results you find
and do what they did.
How many times have you gone through the tutorials for the rc522?
Why do you think an arduino has a port 198.162.0.211?
Paul
Paul_KD7HB, the ip is to send to. UDP command have to send to this ip.
I ve read , really
Geek emeritus..Thanks a lot!
