I Need 4 SPWM for H Bridge Inverter
Hello, i am electrical engineering student and for my final thesis i have to build a H Bridge with gate drivers. For drivers i need 2 different SPWM (in total 4 or maybe i can use the same pins for different MOSFETS idk). I dont know anything about Arduino and bought a kit and started learning it (from a course in Udemy) but i think creating a SPWM is a very advanced task for microcontrollers so probably a beginner cant handle it. I found some codes in GitHub (GitHub - Irev-Dev/Arduino-Atmel-sPWM: Implementation of an sPWM signal) but i am not sure if they can work or not. So I need help here. Can I use that codes and how can i change the frequency and duty cycle? ( I need 0.8 Duty Cycle and 30k-50k f)
Or If you guys know a better code for my task can you please share with me?
Your thesis should also show what you tested and the results.
my test results will be about filtering and harmonics. PWM signal is the least important part of the circuit
