I need a 88 mhz generator
and I was hoping that an arduino could handle it.
The reason that I need it, is because I am trying to repair an AM/FM tuner.
I have the AM portion fixed but the FM is still not working.
I was going to use the same technique that I used for the AM portion.
I injected a 1KHZ signal into the tuner and checked each step in the path to see if it was there. Eventually the signal made it out to the speakers.
I am no good at reading a schematic but I imagine that somewhere in the FM signal path, the tuner will filter out or discard signals that do not fall within the FM frequency band. 88mhz ~ 108mhz.
thanks
Get yourself a cheap Analog Devices DDS chip like an AD9850 on eBay
(sp. "MHz")
[quote author=Perehama date=1535649680 link=msg=3858044https://www.arduino.cc/en/Tutorial/DueSimpleWaveformGenerator[/quote]
  // Read the the potentiometer and map the value  between the maximum and the minimum sample available
  // 1 Hz is the minimum freq for the complete wave
  // 170 Hz is the maximum freq for the complete wave. Measured considering the loop and the analogRead() time
That is going to fall a little short of the desired 88 MHz. :slight_smile:
johnwasser:
Now that you have my head thinking straight, Arduino isn't a good fit for that high of a frequency. It's crystal is traditionally 16 MHz, but can be clocked up to 20 MHz. Any signal generation would be based on that clock speed, or a slower clock, but not higher.
Wishful thinking, and I doubt it.
If you were really injecting a '1KHZ signal' then presumably its a square wave, then that could produce enough harmonics to make its way through a AM receiver to the speakers.
This is not the place to be discussing fixing radio tuners
There is a good reason why a low frequency square wave generator will get through a typical (low frequency) AM receiver to the speakers, but that will be of no use whatsoever for tracking problems in a (high frequency) FM receiver.
