I need a code for loadcell weight reduse rate
I have a load cell with a tank … i want to identify the weigh reduse rate per minute…
I need the arduino code.
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Code for a project is not like a baby; you don't find it under a mulberry bush and it isn't delivered by a stork.
You have to write it.
Or pay someone to write it.
As @ TheMemberFormerlyKnownAsAWOL says, that's the hard reality.
However, You can Google Arduino + load cell and pick up tips from there. When You've decided for a certain load cell there is example code available. I used such example code, picked up the kernel and developed my project, using GPS. The principle is the same, start by using example code.
