I need a little help :))
Hi I just wanted to know if i can write the incoming fragment of a program a little bit shorter...
... Its my first tie using print function and i m tired to google it... :))
#include "Arduino.h"
int LED1 = 13;
Serial.print("A(z)"); Serial.print(LED1); Serial.print("labaknak megfelelo LED-et outputba rakja");
I just wanted to know if i can write the incoming fragment of a program a little bit shorter…
No, you can’t.
In fact you may want to add two spaces (shown as underscores below) to separate the pieces on the screen:
Serial.print("A(z)_"); Serial.print(LED1); Serial.print("_labaknak megfelelo LED-et outputba rakja");
And if you want that to be on the same line but separate from whatever comes later, make the last one a println:
Serial.print("A(z)_"); Serial.print(LED1); Serial.println("_labaknak megfelelo LED-et outputba rakja");
