I Need a P channel mosfet to compliment STP40NF10L
I am making an H bridge and I want a P channel mosfet with similar gate voltage and breakdown voltage. I don't need the max current to be that high. :smiley:
digikey.com has a good search facility for such things.
Maybe this: SUP70101EL https://www.vishay.com/docs/77632/sup70101el.pdf
If you explain what voltage and current the bridge will work at, and if PWM is involved, that will help.
I'd normally use gate drivers and all n-channel FETs for an H-bridge as its the standard way and you
get the benefit of the gate driver protection features and good switching efficiency.
Thanks this is exactly what I wanted. I tried looking in mouser using the find similar tools, but I had no clue on what I was doing.
