I need additional help from old NEO_GPS topic
Original Topic: NEO-GPS sketch no-longer displays number of satellites..
I have two sketches; One displays the # of satellites, and the other does not.
The second sketch also does not display "Altitude" either. Very frustrating. The sketches pretty much look the same to me with the exception of a timer added by Slash Dev. And of course, the second sketch includes more GPS readings.
MY APOLOGIES up front: I started learning Arduino and shortly after got into building and flying drones. It is the most amazing hobby! Next to this of course.
Sketch 1 which displays the # of satellites:
   Motorcycle (GPS) Speedometer
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Fonts/FreeSerif9pt7b.h>
#include <Fonts/FreeSansBold18pt7b.h>
#include <Adafruit_GFX.h>
#include <SPI.h>
#include <NeoSWSerial.h>
NeoSWSerial gps_port(4, 3);  // ASSIGNS PINS 3, 4 FOR GPS RX/TX
#include <NMEAGPS.h>
static NMEAGPS  gps; // This parses the GPS characters
// If using software SPI (the default case):
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
#define OLED_RESET 13
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
  gps_port.begin(9600);
  // request RMC and GGA only
  gps_port.println( F("$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28") );
  display.begin(SSD1306_SWITCHCAPVCC);
  //SPLASH SCREEN
  display.clearDisplay();
  display.setFont(&FreeSerif9pt7b);
  //display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(27, 22);
  display.println( F("Mini-GPS"));
  display.display(); // SEND SPLASH SCREEN
  delay(2000);       // WAIT 2 SECONDS
  //display.setTextSize(0.8);
  display.setCursor(55, 12);
  display.print( F("By"));
  display.setCursor(15, 26);
  display.print( F("Nick Sebring"));
  delay(5000);       // WAIT 5 SECONDS
  if (gps.available( gps_port )) {
    gps_fix fix = gps.read();
    display.clearDisplay(); //CLEAR THE OLED BUFFER, THUS CLEARING THE SCREEN:  GOT IT!
    //  construct data to be sent to the OLED *****************************
    display.setFont();  //reset font to default
    display.setCursor(0, 0);
    display.print( F("Sat: "));
    if (fix.valid.satellites) {
      display.setCursor(25, 0);
      display.println( fix.satellites );
        //TIME
    if (fix.valid.date && fix.valid.time) {
      NeoGPS::clock_t seconds = (NeoGPS::clock_t) fix.dateTime;     // convert pieces to seconds
      // Calculate DST changeover times just once per year
      static NeoGPS::clock_t springTime, fallTime;
      static NeoGPS::time_t  changeover;
      if ((springTime == 0) || (changeover.year != fix.dateTime.year)) {
        changeover.year    = fix.dateTime.year;
        changeover.month   = 3;
        changeover.date    = 14; // latest 2nd Sunday
        changeover.hours   = 2;
        changeover.minutes = 0;
        changeover.seconds = 0;
        changeover.set_day();
        // Step back to the 2nd Sunday, if day != SUNDAY
        changeover.date -= (changeover.day - NeoGPS::time_t::SUNDAY);
        springTime = (NeoGPS::clock_t) changeover;
        changeover.month   = 11;
        changeover.date    = 7; // latest 1st Sunday
        // Step back to the 1st Sunday, if day != SUNDAY
        fallTime = (NeoGPS::clock_t) changeover;
      NeoGPS::clock_t tz = 5;  //  THIS IS WHERE YOU PUT IN YOUR LOCAL TIME ZONE
      if ((springTime <= seconds) && (seconds < fallTime))
        tz--;
      seconds -= tz * 60 * 60;                    // offset seconds to local timezone, including DST
      NeoGPS::time_t localTime( seconds );        // convert seconds back to pieces
      display.setCursor(95, 0);
      if (localTime.hours < 10) {
        display.print( '0' );
      display.print( localTime.hours ); display.print( ':' ); // use pieces
      if (localTime.minutes < 10) {
      display.print( localTime.minutes);
        // Speed
    if (fix.valid.speed) {
      display.setFont(&FreeSansBold18pt7b);
//      display.setTextSize(1);
      display.setCursor(37, 30);
      display.println( fix.speed_mph(), 0);
    //        display.setCursor(10, 57);
    //        if (fix.valid.location) {
    //          display.print(fix.latitude(), 4);
    //          display.print( F(", ") );
    //          display.print(fix.longitude(), 4);
    display.display();
And the second one does not display # of satellited or Altitude Not even the text "ALT"
   Aircraft (GPS) Speedometer
#include <Wire.h>
#include <SPI.h>
#include "NMEAGPS.h"
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
uint32_t timer;
  // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
  Serial.println( F("Acquiring a GPS signal") );
  bool parseDDDMM( int32_t & val, char chr );
  //SPLASH SCREEN
void loop()    // run over and over again
  while (gps_port.available()) {
    timer = millis(); // reset the timer
    if (gps.decode( gps_port.read() ) == NMEAGPS::DECODE_COMPLETED) {
      if (gps.nmeaMessage == NMEAGPS::NMEA_RMC) {
        //  If your device emits a GGA then an RMC each second,
        //    change the above GGA to RMC.  Or if you don't get all
        //    the attributes (e.g., alt, heading, speed and satellites)
        //    try changing the above test.  NMEAorder.ino can be
        //    used to determine which one is last (should be used above).
        //  BTW, this is the safest place to do any time-consuming work,
        //    like updating the display.  Doing it elsewhere will cause GPS
        //    characters to be lost, and some fix data won't be available/valid.
        //    And if you take too long here, you could still lose characters.
        uint32_t displayTime = micros(); // use this later, to figure out how long the display process takes.
        const gps_fix & fix = gps.fix();
        //TIME
            tz--;
        // Speed
          display.setCursor(0, 8);
          display.print( F("MPH: "));
          display.println(fix.speed_mph(), 0);
        // Heading
        if (fix.valid.heading) {
          display.setCursor(78, 8);
          display.print( F("HDG: ")); display.print(fix.heading(), 0);
        // Altitude
        if (fix.valid.altitude) {
          display.setCursor(0, 16);
          display.print( F("Alt: "));
          display.print(fix.altitude(), 0 );
          display.print( F(" FT"));
        //LAT
          display.setCursor(0, 24);
          display.print( F(""));
          display.println(fix.latitude(), 6);
        //LON
          display.setCursor(70, 24);
          display.print( F(" "));
          display.println(fix.longitude(), 6);
        display.display();
Thanks again as always!
NICK
The second sketch seems to have additional checks before processing the data...
If you set one/both of these to
if(true)
What happens?
Thank you sir! That was an issue. Not sure if this is what you meant but, I made the following changes and I now have # of satellites and Altitude on my screen.
#include <Wire.h>
#include <SPI.h>
#define OLED_MOSI   9
#define OLED_CLK   10
#define OLED_DC    11
#define OLED_CS    12
uint32_t timer;
  //SPLASH SCREEN
 //  Remove this to see if it works   if (gps.decode( gps_port.read() ) == NMEAGPS::DECODE_COMPLETED) {
 //     if (gps.nmeaMessage == NMEAGPS::NMEA_RMC) {
// ** DELETE?    gps_fix fix = gps.read();
        //TIME
            tz--;
        // Speed
        // Heading
        // Altitude
        //LAT
        //LON
        display.display();
