I need fix my code to on/off relay
The condition is press button 1 relay 1 on and wait unit till press button 1 relay 1 off. How to fix it. Thank you very much.
My code
#define BLYNK_PRINT Serial    // Comment this out to disable prints and save space
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiManager.h>
ESP8266WiFiMulti wifiMulti;
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h> //Blynk
SimpleTimer timer;
#define WIFI_LED 13
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
char server[] = "XXXXXXXXXXX";
char ssid[] = "ArcHeR-OMEN";
//char ssid[] = "ArcHeR";
char pass[] = "XXXXXXXXX";
int port = 8080;
bool isFirstConnect = true;
int slider;
char Button1 = 0;
char Button2 = 9;
char Button3 = 10;
char Button4 = 14;
char Relay1 = 12;
char Relay2 = 5;
char Relay3 = 4;
char Relay4 = 15;
int buttonState1 = 0;         // variable for reading the pushbutton status
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
BLYNK_CONNECTED() {
if (isFirstConnect) {
Blynk.syncAll();
//Blynk.notify("Device 2 Starting!!!!");
isFirstConnect = false;
Serial.println(String("แอพเริ่มทำงาน!!"));  // used for debugging
  Serial.println("\n Starting");
  wifiMulti.addAP(ssid, pass);
  Serial.println("SSID1");
  Blynk.config(auth, server, port);
  Blynk.connect();   // for a local server requiring WiFi connection
  pinMode(WIFI_LED, OUTPUT);
  pinMode(Button1, INPUT);
  pinMode(Button2, INPUT);
  pinMode(Button3, INPUT);
  pinMode(Button4, INPUT);
  pinMode(Relay1, OUTPUT);
  pinMode(Relay2, OUTPUT);
  pinMode(Relay3, OUTPUT);
  pinMode(Relay4, OUTPUT);
  digitalWrite(Button1, LOW);
  digitalWrite(Button2, LOW);
  digitalWrite(Button3, LOW);
  digitalWrite(Button4, LOW);
  digitalWrite(Relay1, LOW);
  digitalWrite(Relay2, LOW);
  digitalWrite(Relay3, LOW);
  digitalWrite(Relay4, LOW);
  Serial.println("Connecting Wifi...");
    if(wifiMulti.run() == WL_CONNECTED) {
        Serial.println("");
        Serial.println("WiFi connected");
        Serial.println("IP address: ");
  timer.setInterval(15000, reconnectBlynk); // check every 15 seconds if we are connected to the server
void reconnectBlynk() // reconnect to server if disconnected, timer checks every 15 seconds
  if (!Blynk.connected()) {
    if(Blynk.connect()) {
      BLYNK_LOG("Reconnected");
      digitalWrite(WIFI_LED,LOW);
      BLYNK_LOG("Not reconnected");
      digitalWrite(WIFI_LED,HIGH);
 if (Blynk.connected()) {   // to ensure that Blynk.run() function is only called if we are still connected to the server
    Blynk.run();
timer.run();
 if(wifiMulti.run() != WL_CONNECTED) {
        Serial.println("WiFi not connected!");
  buttonState1 = digitalRead(Button1);
  buttonState2 = digitalRead(Button2);
  buttonState3 = digitalRead(Button3);
  buttonState4 = digitalRead(Button4);
    if (buttonState1 == HIGH) {
    // turn LED on:
    digitalWrite(Relay1, HIGH);
    // turn LED off:
     if (buttonState2 == HIGH) {
    // turn LED on:
    digitalWrite(Relay2, HIGH);
    // turn LED off:
    if (buttonState3 == HIGH) {
    // turn LED on:
    digitalWrite(Relay3, HIGH);
    // turn LED off:
       if (buttonState4 == HIGH) {
    // turn LED on:
    digitalWrite(Relay4, HIGH);
    // turn LED off:
result
Condition? Do you mean requirement?
How to fix it.
That depends on how it is broken.
Is something magic supposed to happen while you have your head stuck in the sand?
    // turn LED on:
Why on earth would you name the pin that the LED is connected to Relay1?
The condition is relay 1 on and wait unit till press button 1 relay 1 off.
i mean
press button 1 , one time => Relay/LED 1 on
Press button 1 again => Relay/LED 1 off
sonoff connect by series Relay 1 and led 1 with GPIO 12
  GPIO      function                        schematic
   GPIO  0   Button 1                        E-FW
   GPIO  9   Button 2                        IO  9
   GPIO 10   Button 3                        IO 10
   GPIO 14   Button 4                        IO 14
   GPIO 12   Relay 1                         IO 12
   GPIO  5   Relay 2                         IO  5
   GPIO  4   Relay 3                         IO  4
   GPIO 15   Relay 4                         IO 15
   GPIO  2   Pin 1 Prog Header               SDA
   GPIO 13   Blue LED, Active Low            PWM 1
   GPIO  7   Not connected, jack (see TH16)  GPIO 07
   GPIO  8   Not connected, jack (see TH16)  GPIO 08
   3v3 - jack sleeve
   gnd - jack ring2
