UNO TFT shied
Arduino Mega
DS3231
DS18B20
Hi, my DS3231 generates an interrupt every second (for now). When interrupt occurs, I call displayTemp();
In that routine, I get the temp from DS18b20 and display it on TFT. But every now and then, the screen goes blank or funny colors. This happens when in call showmsgXY(10, 245, 1, &SansSerif_bold_14, result, BLACK);
I tried to print a static string instead of 'result' with same bug. It also doesn't matter what font I'm using (tried system font). I've been working on this for hours now and I don't understand what is goint on...
Can you help?
Also during compilation there are a warnins like this:
C:\Users\Stephane\Documents\Arduino\TFT_test_3\TFT_test_3.ino: In function 'void draw_current_screen(int)':
C:\Users\Stephane\Documents\Arduino\TFT_test_3\TFT_test_3.ino:147:83: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
setup_btn.initButton(&tft, 60, 305, 100, 30, WHITE, CYAN, BLACK, "SETUP", 2);
Is this normal with this library?
CURRENT SCREEN DEFINITIONS
1: Home Screen
2: Adjust Dosing Regimen
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#include <Fonts/FreeSans9pt7b.h>
//#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/SansSerif_bold_14.h>
#include <Fonts/SansSerif_plain_10.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#include <Wire.h>
#include <RTClib.h>
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define GREY 0x8410
#define ORANGE 0xE880
#define MINPRESSURE 200
#define MAXPRESSURE 1000
#define ONE_WIRE_BUS 49
#define CLOCK_INTERRUPT_PIN 19
DeviceAddress thermometerAddress;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature tempSensor(&oneWire);
DateTime now;
RTC_DS3231 rtc;
MCUFRIEND_kbv tft;
const int XP = 6, XM = A2, YP = A1, YM = 7; //ID=0x9341
const int TS_LEFT = 926, TS_RT = 170, TS_TOP = 959, TS_BOT = 174;
int pixel_x, pixel_y;
int current_screen = 0;
int adjust_regimen_day;
float aquarium_temp;
float old_aquarium_temp;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn, back_btn, setup_btn, maint_btn, feed_btn;
tempSensor.begin();
tempSensor.setResolution(thermometerAddress, 11);
rtc.begin();
rtc.disable32K();
pinMode(CLOCK_INTERRUPT_PIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(CLOCK_INTERRUPT_PIN), onAlarm, FALLING);
rtc.clearAlarm(1);
rtc.clearAlarm(2);
rtc.writeSqwPinMode(DS3231_OFF);
rtc.disableAlarm(2);
// rtc.setAlarm1(rtc.now(), DS3231_A1_PerSecond);
rtc.setAlarm1(rtc.now() + TimeSpan(1),DS3231_A1_Second);
uint16_t ID = tft.readID();
tft.begin(ID);
tft.setRotation(3);
draw_current_screen(current_screen);
now = rtc.now();
if(rtc.alarmFired(1)) {
rtc.clearAlarm(1);
bool down = Touch_getXY();
if (current_screen ==0) {
// DAY PRESSED
if (pixel_y > 35 && pixel_y < 80) {
if (pixel_x > 120 && pixel_x <170) { // MONDAY
adjust_regimen_day = 1;
current_screen = 1;
if (current_screen == 1) {
back_btn.press(down && back_btn.contains(pixel_x, pixel_y));
if (back_btn.justPressed()) {
back_btn.drawButton(true);
current_screen = 0;
void draw_current_screen(int x)
switch (x) {
case 0:
tft.fillScreen(BLACK);
tft.setFont(NULL);
/* on_btn.initButton(&tft, 60, 200, 60, 30, WHITE, CYAN, BLACK, "ON", 1);
off_btn.initButton(&tft, 180, 200, 60, 30, WHITE, CYAN, BLACK, "OFF", 1);
on_btn.drawButton(false);
off_btn.drawButton(false);
tft.fillRect(40, 80, 160, 80, RED); */
tft.fillRect(0, 0, 480, 20, GREEN);
showmsgXY(140, 16, 1, &FreeSans9pt7b, "NANO SCAPE QUEBEC", BLACK);
// DOSING REGIMEN
tft.fillRect(0,35,470,45,BLUE);
showmsgXY(30, 55, 1, &SansSerif_bold_14, "Dosing", WHITE);
showmsgXY(30, 72, 1, &SansSerif_bold_14, "Regimen", WHITE);
tft.drawRect(120, 35, 350, 45, YELLOW);
tft.drawFastHLine(120, 57, 350, YELLOW);
tft.drawFastVLine(170, 35, 45, YELLOW);
tft.drawFastVLine(220, 35, 45, YELLOW);
tft.drawFastVLine(270, 35, 45, YELLOW);
tft.drawFastVLine(320, 35, 45, YELLOW);
tft.drawFastVLine(370, 35, 45, YELLOW);
tft.drawFastVLine(420, 35, 45, YELLOW);
showmsgXY(134, 50, 1, &SansSerif_plain_10, "MON", WHITE);
showmsgXY(184, 50, 1, &SansSerif_plain_10, "TUE", WHITE);
showmsgXY(234, 50, 1, &SansSerif_plain_10, "WED", WHITE);
showmsgXY(284, 50, 1, &SansSerif_plain_10, "THU", WHITE);
showmsgXY(334, 50, 1, &SansSerif_plain_10, "FRI", WHITE);
showmsgXY(384, 50, 1, &SansSerif_plain_10, "SAT", WHITE);
showmsgXY(434, 50, 1, &SansSerif_plain_10, "SUN", WHITE);
// PH
tft.fillRoundRect(0,90,80,90,9,GREEN);
showmsgXY(30, 105, 1, &SansSerif_bold_14, "PH", BLACK);
// TEMPERATURE
tft.fillRoundRect(0,190,80,90,9,BLUE);
showmsgXY(10, 205, 1, &SansSerif_bold_14, "TEMP F", BLACK);
// BOTTOM MENU
tft.setFont(NULL);
setup_btn.drawButton(false);
maint_btn.initButton(&tft, 240, 305, 150, 30, WHITE, CYAN, BLACK, "MAINTAIN", 2);
maint_btn.drawButton(false);
feed_btn.initButton(&tft, 420, 305, 100, 30, WHITE, CYAN, BLACK, "FEED", 2);
feed_btn.drawButton(false);
case 1:
showmsgXY(70, 55, 1, &SansSerif_bold_14, "Adjust Dosing Quantity for ", WHITE);
switch (adjust_regimen_day) {
case 1:
showmsgXY(315, 55, 1, &SansSerif_bold_14, "MONDAY", WHITE);
tft.setFont(NULL);
back_btn.initButton(&tft, 30, 305, 60, 30, WHITE, CYAN, BLACK, "BACK", 1);
back_btn.drawButton(false);
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg, uint16_t color)
int16_t x1, y1;
uint16_t wid, ht;
tft.setFont(f);
tft.setCursor(x, y);
tft.setTextColor(color);
tft.setTextSize(sz);
tft.print(msg);
tft.setFont(NULL);
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.y, TS_BOT, TS_TOP, 0, tft.width());
pixel_y = map(p.x, TS_LEFT, TS_RT, 0, tft.height());
return pressed;
void displayTemp() {
char result[4];
tempSensor.requestTemperatures();
aquarium_temp = tempSensor.getTempFByIndex(0);
Serial.println("Interrupt !");
if (aquarium_temp != old_aquarium_temp) {
dtostrf(old_aquarium_temp, 4, 1, result);
showmsgXY(10, 245, 1, &SansSerif_bold_14, result, BLUE);
dtostrf(aquarium_temp, 4, 1, result);
Serial.println(aquarium_temp);
Serial.println(result);
old_aquarium_temp = aquarium_temp;
void showTime()
Serial.print(now.hour());
Serial.print(":");
Serial.print(now.minute());
Serial.print(":");
Serial.print(now.second());
Serial.println(" ");
void onAlarm() {
if (current_screen == 0) {
displayTemp();
