I have an arduino uno R3 with a motor shield. I wanna run a DC motor back and forth. There are two proximity sensor at both ends which are used to reverse the direction of the motor. When the sensor is triggered, it can provide 4V output. So I think I can connect it to the digital input to control the motor. After I put all the stuff together and power it on, the motor just ran back and forth in the middle without reaching any ends.
Here is my code:
#include <AFMotor.h>
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Motor test!");
motor.setSpeed(255); // set the speed to 255/255
pinMode(0,INPUT); // use Pin 0 as digital input
pinMode(1,INPUT); // use Pin 1 as digital input
int VOL1=digitalRead(0); //read voltage from pin 0 which is connected to sensor 0
int VOL2=digitalRead(1); //read voltage from pin 1 which is coneected to sensor 1
static int number=0; //add a static value to determine the direction of motor between two ends
if (VOL1==HIGH) //if sensor 0 is triggered, the motor move forward
motor.run(RELEASE);
motor.run(FORWARD); // turn it on going forward
number++; //number++ will make number be odd
if (VOL2==HIGH) //if sensor 1 is triggerd, the motor move backward
motor.run(RELEASE);
motor.run(BACKWARD);
number++; //number++ will make number be even
if(number%2==1) //if number is odd, which means it just left sensor 0, it should keep going forward until it reaches sensor 1
motor.run(FORWARD);
delay(5);
else //if the number is even, which means it just left sensor 1, it should keep going backward until it reaches sensor 0
delay(5);
I really need some help. So thanks so much if you have some advice or solution.
