I need help as quickly as possible!
So I am doing this project for school where I have to messure the voltage and ampere. I would like to print this on my LCD but I don't now how, I can only see it on my serial monitor. I am new to arduino and programming in general and I would like to now how I am able to do this.
This is the program that I have to messure the voltage ans ampere. Thank you for your help in advance.
float A;
float V; (I am using an 16x2 display)
float h;
void setup () {
Serial.begin (9600);
pinMode (A1, INPUT);
pinMode (A2, INPUT);
void loop () {
V= analogRead (A1)/41.2;
A= analogRead (A2)/183.3;
Serial.print (V);
Serial.print (" V");
Serial.print ("\t");
Serial.print (A);
Serial.println (" A");
1. Kindly reformat the program codes of your post in accordance with the following instructions:
(a) Open your post in the Edit/Modify Mode.
(b) Bring the cursor at the very beginning of your code. Now, type this word: [ c o d e ]. Please, do not keep spaces among the letters while typing the word. Keep them together. I have to keep spaces due to some technical reasons.
(c) Bring the cursor at the very end of your code. Now, type this word: [ / c o d e ]. Please, do not keep spaces among the letters while typing the word. Keep them together. I have to keep spaces due to some technical reasons.
(d) Press the save button.
Now, your codes/post looks so beautiful!
2. Are you using Arduino UNO or MEGA or NANO or DUE?
3. Which one of the following two is your LCD? The Left LCD with a small board underneath is called I2C Bus LCD (I2CLCD). The right LCD with no small board beneath is called Parallel Interface LCD (PLCD).
4. Make a connection between Arduino and LCD; post the picture/connection diagram in the next post.
