I need help atmega1284av
Bought a payment I can not work with Arduino.
Bootloader stitched from 1284P
Somewhere discrepancy of c 1284AU
Help to understand???
it is impossible even to blink the diode
There is PINout but it under DIP
Are you sure that's a 1284P? Surface mount 1284 only has 44 pins, that looks like a lot more.
I have mega1284AU - 44 pin
ATMEGA1284
AU 1047
arduino 0x1902 is defined
I use Usbasp
Okay, you need to create a new entry in your local copy of ardude.conf with the signature bytes for the non-P version of the 1284.
Then create a new entry in boards.txt for that part.
Should be good to go after that.
