I need help choosing an Arduino model
Hi all,
I'm looking to back a keyboard with a built in touch screen in place of the number pad, much like the 'Razer Deathstalker'.
I have the keyboard and I have some touchscreens that came with single board PCs.
I would like a controller to handle the keys and the screen and touch functionality and hopefully make media controller/macros to be used through the touchscreen.
I was hoping someone with more experience could help before I start down the wrong route.
If it complicates the process I can control the keyboard separately.
For information the touchscreen uses an LVDS connector for the screen and a USB header for touch feedback.
Thanks
When you want to learn something there are seldom wrong routes, there might be longer and shorter...
learning that something does not work often gives you more "knowledge" that a first time right.
Do you have links to datasheets of the hardware?
I was mainly meaning I don't want to buy one incapable of being used for my intended use.
I have links to the data sheets yes, had to google the touch controller but here they are:
Screen:
http://www.display-solution.com/pdf/tft-displays/evervision/VGG644804-6UFLWD.pdf
Touch controller:
