system
June 15, 2014, 4:08pm
#1
void main(){
const int ledpin = 13
const int analog_in = A0
const int min_sensorvalue = 0
const int max_sensorvalue = 2000
int sensorvalue = 0
void setup( ){
void loop( ){
sensorvalue = analogRead(analog_in)
if(sensorvalue > max_sensorvalue){
sensorvalue = max_sensorvalue
else if(sensorvalue < min_sensorvalue){
sensorvalue = min_sensorvalue
digitalWrite(ledpin, HIGH)
delay(sensorvalue)
digitalWrite(ledpin, LOW)
I keep getting a ton of error messages when I compile it
update moderatore: replaced quotes with code tags + fixed copy error
BlinkSpeed.ino (459 Bytes)
Do you have question ?
Do you have a complete program by any chance ?
Did you mean to have a main() function or was that just an accident ?
Have you read Read this before posting a programming question ... - Programming Questions - Arduino Forum ?
system
June 15, 2014, 6:08pm
#3
Senor value can only be max of 1023.
digitalWrite(ledpin, [color=#00 ???
the attached ino file is correct , I’ll fix the original Post
system
June 22, 2014, 12:41pm
#6
UKHeliBob:
no, I didn't mean to have a main() function.
Then I am intrigued as to why it was there. As has been suggested you should look at some of the examples to see how an Arduino 'sketch' (horrible word !) is constructed. You can have a main() function if you want but it is normally added invisibly behind the scenes when compiling from the IDE.
