I need help for my code
Hi !
I came here because I really need help for my code. So I have to make a program to make a push button a on/off switch. I found some code parts on internet and assembeld them into this code.
I want to convert the ternary condition to a classic if-else condition but all my atempts didn't work. So I ask if someon has the solution to my problem.
Thanks !
boolean lastButtonState = false;
boolean ledState = false;
  pinMode(2, OUTPUT);
  pinMode(7, INPUT);
  int buttonState = digitalRead(7);
  if (buttonState != lastButtonState) {
    lastButtonState = buttonState;
    if (buttonState == LOW) {
      ledState = (ledState == true) ? LOW: HIGH;
      digitalWrite(2, ledState);
Why? Did your teacher ask you to do it that way?
What have you tried? Post your attempt at doing it and people will help. Writing code for others is not what this forum is about.
Seems straightforward. Do you understand how the ternary operator functions?
See
https://codefinity.com/courses/v2/59a3e4eb-a3a1-49a4-ba70-da98e8fee510/5429077a-e308-4fb9-ba81-7305f195200b/d8948c9a-7af9-4839-ac86-5c191b240295
and read far enough to see how it might look as an if/else statement.
a7
You mean this?
so something like this:
if( some_condition )
   some_variable = this_value;
   some_variable = that_value;
Note that the == true is superfluous - you just need:
ledState = (ledState) ? LOW: HIGH;
Which actually just seems to be inverting the state:
ledState = !ledState;
  pinMode(2, OUTPUT);
  pinMode(7, INPUT); // external signal? if button then pullup needed
  static bool lastButtonState = false;
  bool buttonState = digitalRead(7);
    if (buttonState == LOW)  digitalWrite(2, ! digitalRead(2));
    delay(20);
    while (digitalRead(7) == buttonState);
