i need help for write programme fo arduino
i need programmefor arduno
pwm----->give voltage variable 0 255
after pwm given voltage arduino will Measures voltage for the risitance R4 send A0 (voltage for measures current)
and measures also voltage V+ and send valure to A1 FOR TRACING GRAPH I(v)
|500x313 thx
Trivial.
What R4? Measure it where?
Current that passes through transto jfet and resistot R4
THERE IS CELLULE SOLARE BETWEEN V+ AND V-
It would (possible) be much easier knowing what the project is for.
Regards
projet for Drawing Curve I(v) FOR solar cell THE solar cell BETWEEN v+ and v-
OK. What are you going to do with reading (V, I)?: Display them?. Where?. Do you plan to record -SD card- them?
Regards.
Are you aware of power involved (1 Ohm resistor)?
yes i need programme
I see that you are increasing the current from your (12volt?) solar cell by stepping up the duty cycle of the PWM (R3/C1), and measuring the voltage across the solar cell (R1/R2/A1) and 1ohm/5watt current sense resistor (R4/A0). I assume U1's supply voltage is >=12volt (the source could be 5volt).
Circuit seems ok, except for the ripple on C1. With ~500hz PWM, it is ~0.6volt t/t @ 50%PWM. That could introduce a measuring fault of ~8%. Connecting R3 to pin 5 or 6 doubles the PWM frequency, and halves the error.
Have you written any code? Leo..
no i don’t know how to write programme
pwm -->input it is change 0-----5v
A0—>OUTPUT IT IS CHANGE 0----5v /R4=1hom so I change 0----5ampere
A1----> output it change 0-----5v
arduno save reasult (V;I)
BOUCLE
…EXT
Similar idea
i neesd configrate aeduno for doing that
