I need help I am new. could someone rewrite this for me so it works!?
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino: In function 'void loop()':
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:10:3: error: 'DigiKeyboard' was not declared in this scope
DigiKeyboard.sendKeyStroke(KEY_T, MOD_CONTROL_LEFT);
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:10:30: error: 'KEY_T' was not declared in this scope
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:10:30: note: suggested alternative: 'SREG_T'
SREG_T
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:10:37: error: 'MOD_CONTROL_LEFT' was not declared in this scope
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:14:30: error: 'KEY_N' was not declared in this scope
DigiKeyboard.sendKeyStroke(KEY_N, MOD_CONTROL_LEFT);
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:14:30: note: suggested alternative: 'SREG_N'
SREG_N
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:18:3: error: 'Digikeyboard' was not declared in this scope
Digikeyboard.sendKeyStrokes(KEY_F4);
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:18:31: error: 'KEY_F4' was not declared in this scope
C:\Users\Eddie\AppData\Local\Temp.arduinoIDE-unsaved2025422-12184-5ykbtt.yp4l3\sketch_may22d\sketch_may22d.ino:18:38: error: expected '}' at end of input
exit status 1
Compilation error: 'DigiKeyboard' was not declared in this scope
Here is the code
// New tab
// New window
//Fullscreen toggle
Welcome to the forum!
Try writing #include "DigiKeyboard.h" on a line at the start of the sketch, and writing } on a line at the end of the sketch.
ok i did that using the library and now im getting error code exit statis 1
this is what it looks like now after the changes
#include <DigiKeyboardBe.h>
// New tab
// New window
//Fullscreen toggle
There is a simple trick:
Run the tutorials and learn how the libary works .
Wrap your code in a code block...
Change occurrences of DigiKeyboard to DigiKeyboardBe.
E.g.
DigiKeyboardBe.sendKeyStroke(KEY_T, MOD_CONTROL_LEFT);
i did that and im getting "exit statis 1"
this is what the code looks like now
// New tab
// New window
DigiKeyboardBe.sendKeyStroke(KEY_N, MOD_CONTROL_LEFT);
//Fullscreen toggle
DigiKeyboardBe.sendKeyStrokes(KEY_F4);
If you want to keep my attention, please edit your posts and attach the code how it should be
(see #5).
yea, i dont know how to do that, could you do it?
i dont know where to put it, could you do it?
Do what?
put it in code blocks
Please correct your posts and add code tags around your code.
There is a small pencil image below your existing posts.
  • click on this pencil āžœ that will let you edit your post.
  • Select the part of the text that corresponds to the code
  • Click on the <code/> icon in the toolbar to indicate that it is code
  • click image Save Edit
(Also make sure to properly indent the code in the IDE before copying and pasting it here. This can be done by pressing ctrlT on a PC or cmdT on a Mac)
Do yourself a favour and please read How to get the best out of this forum and post accordingly …
Maybe because you did not do what I suggested, you did something different. Good luck with getting your code to work! :waving_hand:
What occurs when you follow the instructions in Post #13 and Post #5?
#include "DigiKeyBoard.h"
unsigned long start = millis();
while (millis() - start < 900000) {
  DigiKeyboard.delay(200);
Does it "compile?" (click the check mark)
(yes, everyone noticed you changed it from the first few posts)
so i changed the #include to the board in my library but now im getting this error code
In file included from C:\Users\Eddie\AppData\Local\Temp\.arduinoIDE-unsaved2025423-2980-4z2y5r.x2p8h\sketch_may23a\sketch_may23a.ino:1:0:
c:\Users\Eddie\Documents\Arduino\libraries\DigiKeyboardBe\src/DigiKeyboardBe.h:1:10: fatal error: DigiKeyboard.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: exit status 1
You must install the correct library. Spelling.
so everywhere it says digiKeyBoard i should change it to DigiKeyboardBe.h ??
