i am an newbie to the arduino i have found a working code to control relays through lan webserver. i need to access that web page on internet were now i can only access it on my local area network.
WebServerSwitchingV04_06.ino (28.9 KB)
Usually people use a dynamic IP service like http://www.noip.com/ and similar to track dynamic IP situations. Use the forum search feature (upper right of this page) for previous post.
hmm. thanku for reply. an you provide me a sample code.
Web server code that produces a web page with three different types of URL addressing.
//zoomkat 04-10-15
//simple button GET with iframe code
//open serial monitor to see what the arduino receives
//use the ' instead of " in html ilnes
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //ethernet shield mac address
byte ip[] = {
192, 168, 1, 102 }; // arduino IP in lan
byte gateway[] = {
192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server test no-ip 04-10-15"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat\r\n\r\n");
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
client.println("Arduino served LAN: <a href='/?on1' target='inlineframe'>ON</a>");
client.println("<a href='/?off' target='inlineframe'>OFF</a>
client.println("Remote served LAN: <a href='http://192.168.1.102:84/?on1' target='inlineframe'>ON</a>");
client.println("<a href='http://192.168.1.102:84/?off' target='inlineframe'>OFF</a>
client.println("Remote served no-ip: <a href='http://zoomkat.no-ip.org:84/?on1' target='inlineframe'>ON</a>");
client.println("<a href='http://zoomkat.no-ip.org:84/?off' target='inlineframe'>OFF</a>");
client.println("<IFRAME name=inlineframe style='display:none'>");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on1") >0)//checks for on
digitalWrite(4, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(4, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
Making it work is simple (and totally unrelated to Arduino) - just find your IP address with whatismyip.com and configure port forwarding on your router (refer to the documentation for your router - this is beyond the scope of these forums. Depending on your ISP and where you live, you may also have to change settings on your cable modem through a web interface to tell it to let the port through as well - refer to appropriate documentation) such that the port that the webserver on the Arduino is running gets forwarded to the IP address you selected. If option is given, it's TCP.
Then you can use that IP address (the external one, from whatismyip etc) as the IP for the server and connect from anywhere.
However, whether you want to do something like that is another matter, since you've made no provisions for security! That (coupled with the limited resources of arduino processors which preclude effective crypto) is why there are so many services for controlling arduino and similar remotely - people use something like that so their arduino doesn't have to be exposed to incoming connections (which might be malicious)
